dstnat doesn't work on L009UiGS-RM Router
Hello to all Mikrotik enthusiasts,
Merry Christmas and Happy New Year!
I recently purchased a new Mikrotik L009UiGS-RM. Using the default configuration, I’m trying to open port 443 (and other ports) on it, but for some reason—unknown to me—I haven’t been able to.
The ether1 interface has a WAN connection with the public IP address xxx.xx.xx.123. There is another public IP (xxx.xx.xx.122) on the same interface, but you can ignore it for now.
the ip 192.168.88.200 represent my server.
So please advise.
here is my configuration:
[b]# 2024-12-28 18:54:30 by RouterOS 7.12.2
# software id =
# model = L009UiGS
# serial number =
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.88.10-192.168.88.190
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
    192.168.88.0
add address=xxx.xx.xx.123/24 interface=ether1 network=xxx.xx.xx.0
add address=xxx.xx.xx.122/24 interface=ether1 network=xxx.xx.xx.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=src-nat chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN src-address=192.168.88.0/24 to-addresses=\
    xxx.xx.xx.123
    xxx.xx.xx.122
add action=dst-nat chain=dstnat dst-address=xxx.xx.xx.123 dst-port=443 \
    protocol=tcp to-addresses=192.168.88.200 to-ports=443
    protocol=udp to-addresses=192.168.88.200 to-ports=443
add action=dst-nat chain=dstnat dst-address=xxx.xx.xx.123 dst-port=3306 \
    protocol=tcp to-addresses=192.168.88.200 to-ports=3306
add action=dst-nat chain=dstnat dst-address=xxx.xx.xx.123 dst-port=115 \
    protocol=tcp to-addresses=192.168.88.200 to-ports=115
add action=dst-nat chain=dstnat dst-address=xxx.xx.xx.123 dst-port=3389 \
    protocol=tcp to-addresses=192.168.88.200 to-ports=3389
add action=dst-nat chain=dstnat dst-address=xxx.xx.xx.123 dst-port=22 \
    protocol=tcp to-addresses=192.168.88.200 to-ports=22
add action=dst-nat chain=dstnat dst-address=xxx.xx.xx.123 dst-port=80 \
    protocol=tcp to-addresses=192.168.88.200 to-ports=80
add disabled=no dst-address=0.0.0.0/0 gateway=xxx.xx.xx.1 routing-table=main \
    suppress-hw-offload=no
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=LAN[/b]
There is nothing unusual in your configuration, so since it “doesn’t work”, my first question is how do you test it. If you try to connect to x.x.x.123 from a device in 192.168.88.0/24, you would have to set up a “hairpin NAT” to make it work when the server is also in 192.168.88.0/24. But there are better approaches if you need clients in LAN to access a server in LAN via the public address, and if you only need it for testing, it is better to test it from the internet, i.e. the same way it will work in production.
Also, you only need to set to-ports in NAT rules if you want them to change the ports - in your case, it is not necessary. But nor is it harmful.
Hello Sindy.
1-I am testing from outside, but that doesn’t matter—it should work from both sides. I have the exact same setup with my CCR2004, and I can see the port is open from both outside and inside.
2-No, I want to open this port to make my server accessible from outside my LAN.
@Techsystem: could you be so kind and edit your post to apply proper tags for code?
Open a command line window, make it as wide as your screen allows, run /tool sniffer quick port=3389 in it, and try establishing a RDP connection from the test client to the server. It should show you whether the connection attempt arrives at all and if yes, what happens next.
Hey BartoszP, You mean like this above..?
recheck the post.
Perfetto as would Italian say. :slight_smile:
Here is what I get when trying to establish a Remote Desktop connection to the server:
On my side, the connection keeps rendering, and in the end, I receive a “connection timeout” error.
What does /ip arp print where address=192.168.88.200 show? The firewall rules are OK, there are no IPsec policies, no routing tables except main, no rules in raw… so unless there is a typo in the .123 address in the dst-nat rules, if the server at 192.168.88.200 can be pinged from the router itself, it looks like a bug.
Is the target host a Windows machine ?
No host-firewall issues ?
If a Linux, can you do a quick “tcpdump” to see what actually ARRIVES there ?
If a Windows, perhaps quickly install “Wireshark” or something for a test.
Have you ever modified the dst-nat rules or have you put them in exactly the way they look now?
In recent ROS 7 versions, there is a nasty bug with some configuration items - if you modify them, the changes do not make it from the “visible” configuration to the “running” one. In some cases, disabling and enabling that item helps, in other cases it apparently doesn’t. I don’t know since when the bug is there so 7.12.2 may or may not be affected.
In any case, please try the following:
/ip firewall nat add chain=dstnat in-interface=ether1 protocol=tcp dst-port=3389 action=dst-nat to-addresses=192.168.88.200 place-before=[find where dst-port~“3389”]
and then try testing while sniffing like in the first case again.
Are You sure Your ISP isn’t blocking the port? 443 is HTTPS - and ISPs love to block it on residential installations. Set the a firewall rule to log access to this port, and see if something is getting in.
@Paternot, the first sniff result shows that the initial packet for port 3389 did arrive to ether1, so the ISP does not block it.
@Techsystem, @jvanhambelgium’s suggestion made me realize I may have jumped to conclusions too quickly - for the bridge port via which the server at .88.200 is reachable, set hw on the corresponding /interface bridge port row to no and run the sniffer again. Sniffing on ports with hw=yes may not show some traffic.
  1. The first problem I see is that you have both
    an IP address for WAN on ether1 AND a dhcp client on ether1.
    It cannot be both!!!
    If your certain about the IP address disable the dhcp client.
2 Suggest changing this default rule to three rules which are clearer as to the functionality and a bit more secure as well.
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
TO:
add action=accept chain=forward comment=“internet traffic” in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment=“port forwarding” connection-nat-state=dstnat
add action=drop chain=forward comment=“drop all else”
  1. Masquerade rules are misleading in that the comments should be removed ( these are action sourcenat NOT masquerade )
    I dont think you need source address of the lan either but probably no harm.
“defconf: masquerade”** ipsec-policy=
xxx.xx.xx.123
add action=src-nat chain=srcnat comment=“defconf: masquerade” ipsec-policy=
xxx.xx.xx.122
  1. Other than that, dont see anything.
Of course it can be both, but one need to /really/ know that’s what they want.
Case in point, DOCSIS cable modems have the hard-coded-in-standard 192.168.100.1 IP for the management interface.
I have the modem configured in bridge mode, so it assigns me an upstream IP by DHCP and a gateway IP somewhere “up there” in ISP’s network. It does not do any routing tasks.
And so, I have secondary static 192.168.100.2 IP configured on the very same WAN interface next to the DHCP client, so I can access the modem and the internet at the same time.
Port 3389. He was complaining about port 443, wasn’t he? Here is quite common for ISPs to block ports below 1024. Don’t know about his case though.
Linux..
I will when I get back to my office.
I tried disabling and enabling all the items, but that doesn’t work.
here is the result
