dstnat on a specific VPN
Hello everyone
I got vpn (PPTP1) on the router that the whole traffic route thorough that, now I want to keep it the same way but only route all /ip firewall nat add action=dst-nat chain=dstnat dst-port=XXXX protocol=tcp to-addresses=192.168.XX.XX to-ports=XX thorough an other vpn (PPTP2).
So two active vpn one (PPTP1) for everything and another one (PPTP2) just for /ip firewall nat add action=dst-nat chain=dstnat addresses with the specified port.
This is my configuration:
export config.txt (6.58 KB)
up up
up up
Is it even possible?
Yes, read this post, starting from the last paragraph which relates it to your context. Think about your two VPN tunnels as WANs.
Loosely related - PPTP provides almost no security, its encryption is ridiculously week from nowaday’s perspective. L2TP/IPsec is equally simple (or complex) to configure and much more secure.
