I have an rb133 which is working well except that I cannot get dstnat to work. The rb133 is running MikroTik RouterOS 2.9.38.
I have ether1 as the outside with ether2 as the dmz and ether3 as the main network. I have wlan1 also working fine.
I have had to put my mail and web servers on the outside ( I have iptables running on them so it is OK. )
I have for the dstnat section:
ip address add address=192.168.1.133/29 interface=ether1
ip route add dst-address=0.0.0.0 gateway=192.168.1.129
ip address add address=10.100.100.1/26 interface=ether2
ip firewall nat add chain=dstnat dst-address=192.168.1.133 protocol=tcp dst-port=22 action=dst-nat to-addresses=10.100.100.5 to-port=22 disabled=no
ip firewall nat add chain=srcnat src-address=10.100.100.5 action=src-nat to-addresses=192.168.1.133 disabled=no
ip firewall nat add chain=srcnat out-interface=ether1 action=masquerade
The srcnat part works fine. If I login to a friends machine from 10.100.100.5 It shows that I am on address 192.168.1.133. However, It will not connect to 192.168.1.133 from the outside.
Thanks for the help
Henryg
