Hello everyone,
At the last couple of weeks im working on wordpress site in my local lab, the site got to situation when i want to get others opinions so i had “port forward” any ingress traffic from WAN with dst-port 8080 using the following dstnat rule
#masquerade is shown for your information.
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface-list=WAN log=no log-prefix="mesqu" ipsec-policy=out,none
1 ;;; enable remote access to wordpress
chain=dstnat action=dst-nat to-addresses=192.168.88.35 to-ports=8080 protocol=tcp dst-port=8080 log-prefix=""
Later that day i’ve found that my IPTV stops work when trying to zapping channels, i’ve started to debug the communication of my streamer and found that the my streamer (ip 88.10) start session with IPTV server on port 80 then 8080 and then for some reason trying to communicate with wordpress server (ip 88.35) on port 8080 which on same subnet.
1 0.000000 192.168.88.10 212.150.225.64 TCP 74 54538 → 80 [SYN] Seq=0 Win=65535 Len=0 MSS=1460 SACK_PERM=1 TSval=4204672 TSecr=0 WS=64
2 0.043196 192.168.88.10 224.0.0.251 MDNS 443 Modified by pacmen
3 0.212710 192.168.88.10 194.90.120.134 TCP 74 39330 → 8080 [SYN] Seq=0 Win=65535 Len=0 MSS=1460 SACK_PERM=1 TSval=4204736 TSecr=0 WS=64
4 0.213260 192.168.88.35 192.168.88.10 TCP 74 8080 → 39330 [SYN, ACK] Seq=0 Ack=1 Win=65160 Len=0 MSS=1460 SACK_PERM=1 TSval=2344763495 TSecr=4204736 WS=128
5 0.216328 192.168.88.10 192.168.88.35 TCP 56 39330 → 8080 [RST] Seq=1 Win=0 Len=0
6 1.895825 192.168.88.10 212.150.225.64 TCP 74 54542 → 80 [SYN] Seq=0 Win=65535 Len=0 MSS=1460 SACK_PERM=1 TSval=4205240 TSecr=0 WS=64
7 2.906893 192.168.88.10 212.150.225.64 TCP 74 [TCP Retransmission] 54542 → 80 [SYN] Seq=0 Win=65535 Len=0 MSS=1460 SACK_PERM=1 TSval=4205544 TSecr=0 WS=64
8 4.266561 192.168.88.10 194.90.120.134 TCP 74 [TCP Retransmission] 39330 → 8080 [SYN] Seq=0 Win=65535 Len=0 MSS=1460 SACK_PERM=1 TSval=4205952 TSecr=0 WS=64
9 4.267134 192.168.88.35 192.168.88.10 TCP 74 [TCP Previous segment not captured] [TCP Port numbers reused] 8080 → 39330 [SYN, ACK] Seq=63343454 Ack=1 Win=65160 Len=0 MSS=1460 SACK_PERM=1 TSval=2344767549 TSecr=4205952 WS=128
10 4.269848 192.168.88.10 192.168.88.35 TCP 56 39330 → 8080 [RST] Seq=1 Win=0 Len=0
11 5.120036 192.168.88.10 212.150.225.64 TCP 74 [TCP Retransmission] 54542 → 80 [SYN] Seq=0 Win=65535 Len=0 MSS=1460 SACK_PERM=1 TSval=4206208 TSecr=0 WS=64
12 5.586699 192.168.88.10 104.199.64.255 SSL 77 Continuation Data
So I’ve figured it as something to do with my new nat rule but I didn’t understard why, i disable the dstnat rule and recorded working session initialization.
|Time | 192.168.88.10 |
| | | 194.90.120.134 |
|0.000000 | 39616 → 8080 [SYN] S |TCP: 39616 → 8080 [SYN] Seq=0 Win=65535 Len=0 MSS=1460 SACK_PERM=1 TSval=4391776 TSecr=0 WS=64
| |(39616) ------------------> (8080) |
|0.005902 | 8080 → 39616 [SYN, A |TCP: 8080 → 39616 [SYN, ACK] Seq=0 Ack=1 Win=4380 Len=0 MSS=1460 TSval=2599415847 TSecr=4391776 SACK_PERM=1
| |(39616) <------------------ (8080) |
|0.008820 | 39616 → 8080 [ACK] S |TCP: 39616 → 8080 [ACK] Seq=1 Ack=1 Win=65535 Len=0 TSval=4391778 TSecr=2599415847
|0.012245 | GET /ngx/out/u/12_pr |HTTP: GET /ngx/path/to/index.m3u8?smil_profile=androidtv_4k&token=sometokenandotherinfo HTTP/1.1
|0.018035 | 8080 → 39616 [ACK] S |TCP: 8080 → 39616 [ACK] Seq=1 Ack=260 Win=4639 Len=0 TSval=2599415859 TSecr=4391779
|0.068688 | HTTP/1.1 302 Found |HTTP: HTTP/1.1 302 Found
|0.072245 | 39616 → 8080 [ACK] S |TCP: 39616 → 8080 [ACK] Seq=260 Ack=336 Win=65535 Len=0 TSval=4391797 TSecr=2599415910
|0.073067 | 39616 → 8080 [FIN, A |TCP: 39616 → 8080 [FIN, ACK] Seq=260 Ack=336 Win=65535 Len=0 TSval=4391797 TSecr=2599415910
|0.078760 | 8080 → 39616 [ACK] S |TCP: 8080 → 39616 [ACK] Seq=336 Ack=261 Win=4639 Len=0 TSval=2599415920 TSecr=4391797
|0.079257 | 8080 → 39616 [FIN, A |TCP: 8080 → 39616 [FIN, ACK] Seq=336 Ack=261 Win=4639 Len=0 TSval=2599415920 TSecr=4391797
|0.080738 | 39616 → 8080 [ACK] S |TCP: 39616 → 8080 [ACK] Seq=261 Ack=337 Win=21729 Len=0 TSval=4391800 TSecr=2599415920
If you confused as i do i still kept the best.
I enabled the wordpress dstnat rule again and also log activity when this rule is executed (hited) and got the following when zapping again.
17:38:10 firewall,info dstnat: in:bridge out:(unknown 0), src-mac e0:b6:55:ea:32:e6, proto TCP (SYN), 192.168.88.10:36788->194.90.120.134:8080, len 60
Which to my eyes looks like that the rule is also executed when a egress traffic tries to get out of the nat thats what redirect my streamer to my wordpress server, although this rule is dstnat chain which from my understanding applies to traffic originated from the WAN towards the LAN wordpress server so it shouldn’t be executed.
I managed to solve this issue by applying ‘in-interface=wan’ which makes my confusion grow.
chain=dstnat action=dst-nat to-addresses=192.168.88.35 to-ports=8080 protocol=tcp in-interface=Port 1 - Wan dst-port=8080 log=yes log-prefix=""
I’ve post this issue as i’ve looked at the firewall wiki and according to what i’ve read there, i got confused as following results.
Would appreciate if you could put some sense
model: 2011iL
firmware-type: ar9344
factory-firmware: 3.10
current-firmware: 6.46.5
upgrade-firmware: 6.46.5
