Dual default IPv6 gateways
Hello!
I have RB4011 and trying to set it up to use 2 IPv6 interfaces, while each one can be used as default gateway.
  1. I have single IPv6 address on my ether1 (2a00:xxxx::61) from my ISP
  2. I have /64 on 6to4interface from HurricaneElectric (2001:470:xxxx::2/64). I’ve also have /48 from HE.
  3. Mobile clients that have only IPv4 connectivity in their origin (IPv4 and static-assigned IPv6 from fd2a:93ec:7070::/64 pool at wireguard interface) using RB4011 as VPN server to access IPv4 and IPv6 resources via NAT (yes, I know it’s a shit to use NAT for IPv6).
I want that RB4011 could be accessible both from ether1 and 6to4interface addresses, default gw for RB4011 itself should be via ether1, but all IPv6 traffic from Wireguard clients should go via 6to4interface from HE. I don’t know if it is possible to redistribute IPv6 addresses from /48 HE to Wireguard clients, if it is possible it will be much better.
After setting up addresses, routes and wireguard I’m getting such situation that only one gw is working.
IPv6 address config:
[admin@MikroTik] > ipv6 address print
Flags: I - INVALID, D - DYNAMIC; G - GLOBAL, L - LINK-LOCAL
Columns: ADDRESS, FROM-POOL, INTERFACE, ADVERTISE
#    ADDRESS                       FROM-POOL  INTERFACE          ADVERTISE
0  G 2a00:xxxx::61/64				ether1             no
1 DL fe80::6d5a:e59c:d0e5:2f0b/64		wireguard1_srv     no
2 DL fe80::2ec8:xxxx:xxxx:5331/64		bridge             no
3 DL fe80::2ec8:xxxx:xxxx:5330/64		ether1             no
4  G fd2a:93ec:7070::1/64          pool1_ula    wireguard1_srv     no
5  G 2001:470:xxxx::2/64			6to4-tunnel1       no
6 DL fe80::3:25e4:58ed/64			6to4-tunnel1       no
Static routes:
[admin@MikroTik] > ipv6 route print
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT, s - STATIC; + - ECMP
Columns: DST-ADDRESS, GATEWAY, DISTANCE
#      DST-ADDRESS               GATEWAY             DISTANCE
0  As+ 2000::/3                  2001:470:xxxx::1 	1
1  As+ 2000::/3                  2a00:xxxx::1		1
  DAc  2001:470:xxxx::/64      6to4-tunnel1		0
  DAc  2a00:xxxx::/64      	ether1			0
  DAc  fd2a:93ec:7070::/64       wireguard1_srv		0
  DAc  fe80::%ether1/64          ether1			0
  DAc  fe80::%bridge/64          bridge			0
  DAc  fe80::%6to4-tunnel1/64    6to4-tunnel1		0
IPv6 rule in NAT table to pass Wireguard clients via HE:
[admin@MikroTik] /ipv6/firewall/nat> print
Flags: X - disabled, I - invalid; D - dynamic
 0    chain=srcnat action=src-nat to-address=2001:470:xxxx::2/128 out-interface=6to4-tunnel1 log=no log-prefix=""
Ping using source address seems to be ok, as target is much closer to 2a00.
[admin@MikroTik] > ping 2a02:xxxx:0ff src-address=2a00:xxxx::61
  SEQ HOST                                     SIZE TTL TIME       STATUS
    0 2a02:xxxx:0ff                          56  59 4ms783us   echo reply
    1 2a02:xxxx:0ff                          56  59 4ms691us   echo reply
    2 2a02:xxxx:0ff                          56  59 4ms763us   echo reply
    3 2a02:xxxx:0ff                          56  59 4ms705us   echo reply
    4 2a02:xxxx:0ff                          56  59 4ms556us   echo reply
    sent=5 received=5 packet-loss=0% min-rtt=4ms556us avg-rtt=4ms699us max-rtt=4ms783us
[admin@MikroTik] > ping 2a02:xxxx:0ff src-address=2001:470:xxxx::2
    0 2a02:xxxx:0ff                          56  56 29ms550us  echo reply
    1 2a02:xxxx:0ff                          56  56 29ms705us  echo reply
    2 2a02:xxxx:0ff                          56  56 29ms808us  echo reply
    3 2a02:xxxx:0ff                         56  56 29ms651us  echo reply
    4 2a02:xxxx:0ff                          56  56 29ms760us  echo reply
    sent=5 received=5 packet-loss=0% min-rtt=29ms550us avg-rtt=29ms694us max-rtt=29ms808us
But when I’m trying to use interface as source with the same target, something gets wrong, 47ms on both variants.
[admin@MikroTik] > ping 2a02:xxxx:0ff interface ether1
    0 2a02:xxxx:0ff                                            timeout
    1 2a02:xxxx:0ff                          56  57 47ms200us  echo reply
    2 2a02:xxxx:0ff                          56  57 47ms272us  echo reply
    3 2a02:xxxx:0ff                          56  57 47ms246us  echo reply
    4 2a02:xxxx:0ff                          56  57 47ms343us  echo reply
    sent=5 received=4 packet-loss=20% min-rtt=47ms200us avg-rtt=47ms265us max-rtt=47ms343us
[admin@MikroTik] > ping 2a02:xxxx:0ff interface 6to4-tunnel1
    0 2a02:xxxx:0ff                          56  57 47ms386us  echo reply
    1 2a02:xxxx:0ff                          56  57 47ms348us  echo reply
    2 2a02:xxxx:0ff                          56  57 47ms309us  echo reply
    3 2a02:xxxx:0ff                          56  57 47ms293us  echo reply
    4 2a02:xxxx:0ff                          56  57 47ms334us  echo reply
    sent=5 received=5 packet-loss=0% min-rtt=47ms293us avg-rtt=47ms334us max-rtt=47ms386us
The second problem as default route from 4011 also uses HE:
    0 2a02:xxxx:0ff                          56  57 47ms362us  echo reply
    1 2a02:xxxx:0ff                          56  57 47ms386us  echo reply
    2 2a02:xxxx:0ff                          56  57 47ms223us  echo reply
    3 2a02:xxxx:0ff                          56  57 47ms369us  echo reply
    4 2a02:xxxx:0ff                          56  57 131ms248us echo reply
    sent=5 received=5 packet-loss=0% min-rtt=47ms223us avg-rtt=64ms117us max-rtt=131ms248us
[admin@MikroTik] > tool traceroute 2a02:xxxx:0ff
Columns: ADDRESS, LOSS, SENT, LAST, AVG, BEST, WORST, STD-DEV
#  ADDRESS                   LOSS  SENT  LAST     AVG   BEST  WORST  STD-DEV
1  2001:470:xxxx::1        0%       3  24.7ms   24.8  24.7  25     0.1
8  2a02:xxxx:ff         0%       2  47.4ms   47.3  47.2  47.4   0.1
And the third problem is that RB4011 is not accessible via 2a00:xxxx::61 on ether1. But accessible from HE via 2001:470:xxxx::2.
pts@MacBook-Air-pts ~ % ping6 2a00:xxxx::61
PING6(56=40+8+8 bytes) 2a03:xxxx:aec4 --> 2a00:xxxx::61
^C
--- 2a00:xxxx::61 ping6 statistics ---
17 packets transmitted, 0 packets received, 100.0% packet loss
But Wireguard clients use IPv6 from HE, as they should.
Next, I’ve tried to change Distance in IPv6 routes, to set in such way:
0   s 2000::/3                  2001:470:xxxx::1	2
1  As 2000::/3                  2a00:xxxx::1		1
Now my 4011 is accessible via 2a00:xxxx::61 on ether1, default route also uses ether1 and directly connected IPv6 from ISP.
16 bytes from 2a00:xxxx::61, icmp_seq=0 hlim=57 time=72.093 ms
16 bytes from 2a00:xxxx::61, icmp_seq=1 hlim=57 time=13.964 ms
16 bytes from 2a00:xxxx::61, icmp_seq=2 hlim=57 time=25.752 ms
16 bytes from 2a00:xxxx::61, icmp_seq=3 hlim=57 time=32.601 ms
16 bytes from 2a00:xxxx::61, icmp_seq=4 hlim=57 time=29.309 ms
^C
5 packets transmitted, 5 packets received, 0.0% packet loss
round-trip min/avg/max/std-dev = 13.964/34.744/72.093/19.707 ms
[admin@MikroTik] > ping 2a02:xxxx:ff
    0 2a02:xxxx:ff                           56  59 4ms759us   echo reply
    1 2a02:xxxx:ff                           56  59 4ms743us   echo reply
    2 2a02:xxxx:ff                           56  59 4ms741us   echo reply
    3 2a02:xxxx:ff                           56  59 4ms685us   echo reply
    sent=4 received=4 packet-loss=0% min-rtt=4ms685us avg-rtt=4ms732us max-rtt=4ms759us
1  2a00:xxxx::1         0%       3  0.6ms    0.6  0.5   0.6    0
5  2a02:xxxx:ff          0%       2  4.7ms    4.7  4.7   4.7    0
But…
    0 2a02:xxxx:ff                          56  59 4ms819us   echo reply
    1 2a02:xxxx:ff                          56  59 4ms723us   echo reply
    2 2a02:xxxx:ff                          56  59 4ms666us   echo reply
    3 2a02:xxxx:ff                          56  59 4ms831us   echo reply
    sent=4 received=4 packet-loss=0% min-rtt=4ms666us avg-rtt=4ms759us max-rtt=4ms831us
    0                                                              no route to host
    1                                                              no route to host
    2                                                              no route to host
    3                                                              no route to host
    4                                                              no route to host
    sent=5 received=0 packet-loss=100%
    0 2a02:xxxx:ff                          56  59 4ms784us   echo reply
    1 2a02:xxxx:ff                          56  59 4ms679us   echo reply
    2 2a02:xxxx:ff                          56  59 4ms766us   echo reply
    3 2a02:xxxx:ff                          56  59 4ms707us   echo reply
    sent=4 received=4 packet-loss=0% min-rtt=4ms679us avg-rtt=4ms734us max-rtt=4ms784us
    0 2a02:xxxx:ff                          56  56 29ms768us  echo reply
    1 2a02:xxxx:ff                          56  56 29ms737us  echo reply
    2 2a02:xxxx:ff                          56  56 29ms607us  echo reply
    3 2a02:xxxx:ff                          56  56 29ms709us  echo reply
    sent=4 received=4 packet-loss=0% min-rtt=29ms607us avg-rtt=29ms705us max-rtt=29ms768us
It seems quite strange that I’m getting no route to host, as route persists in route table. Wireguard clients also lose their IPv6 connectivity from HE. And 4011 also becomes unavailable via HE 2001:470:xxxx::2.
Are there any v6 experts who can help me with this issue?
How to make 4011 both accessible from ISP and HE addresses, use default ISP for outgoing IPv6 connections and force Wireguard clients to use HE-only for outgoing/incoming connections?
Is it possible to use /64 from /48 HE to pass real IPv6 addresses to Wireguard clients?
I think you could try to create new routing table (fib), change your HE default route “routing table” to newly created and force wg clients subnet (and yes, you can use some /64 from /48 for wg clients) to lookup to this routing table via routing rules
