Dear experts,
I’m asking if someone could give clear walk-through for the following scenario:
Currently I had one dynamically assigned WAN with two different LAN networks 192.168.0.0/24 and 10.0.0.0/24.
first ISP is connected to ether-1, ether 2-5 are on bridge for LAN1, 6-10 are on a second bridge for LAN2
LAN1 is our local office network, LAN 2 is for guests only and it has access only to internet.
Everything was working flawlessly for a while, until we started to have frequent issues with the connection to the ISP.
So we purchased secondary connection via different ISP and it will be connected to ether-11
I know that there are several topics on the subject, but I cannot find clear answer and example how to achieve it.
Should it be set-up as a fail-over, or is it better to use PCC?
Bot connections have enough bandwidth so it is not really a concern to balance them.
What is the most important for the office is to have stable internet connection without problem accessing and opening banks, mails, etc.
most of the examples I found were for configuration with static WAN and/or GATEWAY address.
However both of the ISP give dynamic addresses, and also the gateway changes on almost every address renewal.
So please advise what would be the best scenario and how to achieve it.
Should I use PCC, or only fail-over? If it is the second should I mark the connections or not? How I can address the dynamic gateway situation. Also what to use to check if the connection is alive? since both WAN connections are fiber and usually the DGW is the media convertor which is just next to the router. So I can access GW, but still don’t have internet.
If using fail-over how to check if “primary” ISP is up and redirect again all traffic via this interface?
Thank you
