hi Dears i have two source internet i get from two router (Different ISP ,Different Speed ) I need Combined Two Speed , I Read about that but all solutions just load balancing.
Hi , If You Are Searching For A Easy & Powerful Way To LOAD BALANCE AND FAILOVER PLEASE HAVE A LOOK AT :
That’s because load-balancing is the only thing you can do with your 2 channels, really… I mean you cannot use your two channels as a single “fat” channel, the only thing you can do is to distribute your traffic between these two channels in some clever way.
