I have the following setup:
- primary ISP1, static ip, 300Mbit connection (has rp_filter enabled)
- secondary ISP2, static ip, 20Mbit connection (no rp_filter)
I am forwarding some ports (same) from both ISP to some ip’s on the lan. I’m using mangle for marking and routes with rules for both ISPs, like in https://wiki.mikrotik.com/wiki/Manual:PCC but without the PCC rules, as I only need the secondary connection for backup and for some of the services only.
The problem is that I’m messing something because currently, with my setup, I can connect to the router from the internet, on both ISPs, but I can’t connect to the internal servers from the second ISP. If I change the primary ISP route distance lower than the secondary, I can connect using the external IPs to the internal servers, but the connection is going out from the Mikrotik through the secondary ISP, who’s accepting packets with other ISP source IP.
I’ve also disabled fasttrack-connection from firewall filter, but all is the same, only with a lower internet throughput and almost 100% cpu usage.
Please help me understand what I’m doing wrong.
Here are my rules:
mangle:
/ip firewall mangle
add action=accept chain=prerouting dst-address-list=Connected src-address-list=Connected
add action=mark-routing chain=prerouting connection-mark=ISP2 new-routing-mark=ISP2 passthrough=no src-address-list=LAN
add action=mark-routing chain=prerouting connection-mark=ISP1 new-routing-mark=ISP1 passthrough=no src-address-list=LAN
add action=mark-connection chain=input connection-mark=no-mark in-interface=ISP1 new-connection-mark=ISP1 passthrough=no
add action=mark-connection chain=input connection-mark=no-mark in-interface=ISP2 new-connection-mark=ISP2 passthrough=no
add action=mark-connection chain=forward connection-mark=no-mark in-interface=ISP1 new-connection-mark=ISP1 passthrough=no
add action=mark-connection chain=forward connection-mark=no-mark in-interface=ISP2 new-connection-mark=ISP2 passthrough=no
add action=mark-routing chain=output connection-mark=ISP1 new-routing-mark=ISP1 passthrough=no
add action=mark-routing chain=output connection-mark=ISP2 new-routing-mark=ISP2 passthrough=no
add distance=10 gateway=x.x.x.1 pref-src=x.x.x.186 routing-mark=ISP1
add distance=10 gateway=y.y.y.209 pref-src=y.y.y.210 routing-mark=ISP2
add check-gateway=ping distance=10 gateway=x.x.x.1 pref-src=x.x.x.186
add check-gateway=ping distance=10 gateway=y.y.y.209 pref-src=y.y.y.210
/ip route rule
add routing-mark=ISP1 table=ISP1
add routing-mark=ISP2 table=ISP2
add action=dst-nat chain=dstnat dst-address-list=ext-ips dst-port=53 protocol=udp to-addresses=192.168.0.25
add action=dst-nat chain=dstnat dst-address-list=ext-ips dst-port=21,22 protocol=tcp to-addresses=192.168.0.35
add action=dst-nat chain=dstnat dst-port=37771 in-interface-list=WAN protocol=udp to-addresses=192.168.0.11
add action=dst-nat chain=dstnat dst-port=81,37711 in-interface-list=WAN protocol=tcp to-addresses=192.168.0.11
/ip firewall address-list
add address=192.168.0.0/24 list=Connected
add address=192.168.88.0/24 list=Connected
add address=y.y.y.210 list=ext-ips
add address=x.x.x.186 list=ext-ips
add interface=ISP1 list=WAN
add interface=ISP2 list=WAN
add interface=bridge list=LAN
I’ve edited the post as the multiple code snippets seems to broke the display, so I’ve added all code in one.
