Hey guys,
Been trying to get this to work with some of the suggestions on the forums but I cannot get it to work.
RB751G
Port 1= WAN1
Port 2= LAN1
Port 3= WAN2
Port 4= LAN2
Wifi = Bridged with LAN2
Anybody have specific instructions for this setup?
Any help is greatly appreciated.
Regards
vk7zms
July 31, 2012, 6:24am
2
OK - so you need to be just a little bit more specific
Do you want LAN1 & LAN2 to both use WAN1 & WAN2? If so is this on a load sharing or fail-over basis?
OR, do you want LAN1 to us WAN1 only, and LAN2 to use WAN2 only?
What type of WAN connections are you using DHCP-Client, L2TP, PPPoE, etc ?
Do you want devices on LAN1 to be able to access devices on LAN2?
vk7zms:
LAN1 to use WAN1 which is a static IP.
LAN2 to use WAN2 which is a static IP.
The WAN’s are from 2 different ISP’s
For now LAN1 & 2 do not need to talk to each other, but this will be something i will need later on.
vk7zms
July 31, 2012, 11:07pm
4
I think the easiest way is with a couple of mangle rules
lets assume the following
LAN1 is 192.168.1.0/24
LAN2 is 192.168.2.0/24
default gateway of ISP1 is 10.1.0.1
default gateway of ISP2 is 10.2.0.1
you could add a couple of mangle rules to mark the traffic from each LAN
chain=prerouting action=mark-routing new-routing-mark=wan1 passthrough=yes
src-address=192.168.1.0/24 dst-address=!192.168.2.0/24
in-interface=lan1
chain=prerouting action=mark-routing new-routing-mark=wan2 passthrough=yes
src-address=192.168.2.0/24 dst-address=!192.168.1.0/24
in-interface=lan2
Now that all the traffic inbound from the LAN ports is tagged with a routing mark, add a couple of default routes to direct the traffic out the appropriate WAN ports
dst-address=0.0.0.0/0 gateway=10.1.0.1 gateway-status=10.0.0.1 unreachable distance=1 scope=30
target-scope=10 routing-mark=wan1
dst-address=0.0.0.0/0 gateway=10.0.0.1 gateway-status=10.2.0.1 unreachable distance=1 scope=30
target-scope=10 routing-mark=wan2
note - by adding the dst-address=!192.168.x.0/24 to the mangle rules, traffic bound from LAN1 to LAN2 will not get caught with the routing mark and will route between the two LAN ports uninterupted
vk7zms:
in-interface=lan1
in-interface=lan2
Great. I’ll try this out and let you know the outcome.
Thank you very much.
vk7zms:
in-interface=lan1
in-interface=lan2
Quick question though. Wouldn’t the src-address on the mangle rules be the WAN ip’s instead of the other LAN ip?
vk7zms
August 2, 2012, 2:09am
7
no - the source address needs to be the address the traffic originates from from, which is inevitably inside your LAN(s).
if for instance you open a webpage from a client on one of the LAN’s, the router will see the traffic coming from the Ethernet port into the router - hence the source address we need to identify, is that of each LAN address range
