Hi all,
I’m not entirely sure the best way to explain this, but I’m trying to do something similar to this guy: http://forum.mikrotik.com/t/lan-users-multiple-pppoe-gateways/62449/1
The below image should help:
What I need is two separate PPPoE connections going down the same physical WAN. From here I need a separate LAN port for each PPPoE connection (kindof the opposite of failover) - essentially to run two customers on one MikroTik.
Does anyone have any ideas on the best way to do this? I’ve been playing around with mangle but I couldn’t get it to behave correctly - I also tried MetaRouter and didn’t get far but that’s probably not the most ideal solution anyway.
Thanks!
