I have a RB493 / ROSv5.25 connecting one LAN to two other LANs as shown here
/ip address print
# ADDRESS NETWORK INTERFACE
0 192.168.10.1/24 192.168.10.0 Local
1 D 192.168.7.64/24 192.168.7.0 WAN1
2 D 192.168.1.65/24 192.168.1.0 WAN2
The desire is to have only specific traffic pass through one network and all other traffic pass through the other network.
I created a mangle rule that looks like this:
/ip firewall mangle print
0 chain=prerouting action=mark-routing new-routing-mark=web_traffic passthrough=no protocol=tcp dst-address-type=!local in-interface=bridge1 dst-port=20,21,22,23,25,53,80,110,443,587,992,993,995
I also have a routing table that looks like this:
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.1.254 routing-mark=web_traffic scope=30 target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.7.254 scope=30 target-scope=10
I have a NAT config that looks like this:
add action=masquerade chain=srcnat disabled=no out-interface=WAN2-NEW
add action=masquerade chain=srcnat disabled=no out-interface=WAN1-OLD
Very basic and simple and it mostly works… But… There is always a but…
From time to time and at random intervals no traffic is passing through the router. For example, pinging from the router console while also pinging from a PC behind this router receives a “Net Unreachable” message to appear randomly at times and sometimes it is the majority of the time as seen here:
4.2.2.2 56 55 30ms
4.2.2.2 56 55 30ms
192.168.7.254 56 255 0ms net unreachable
4.2.2.2 56 55 31ms
4.2.2.2 56 55 32ms
sent=1140 received=766 packet-loss=32% min-rtt=26ms avg-rtt=30ms
max-rtt=49ms
HOST SIZE TTL TIME STATUS
192.168.7.254 56 255 1ms net unreachable
This thing can go for days with no issues at all and then it will act up for a part of a day or like this time for nearly two full days straight.
Are there any suggestions in how I could diagnose this issue and or suggestions on any router programming changes that should be made.
Thank you in advance for any assistance you might be able to forward.
