I have a dual nstreme link both with RB333. I notice that when I disabled then enable back again the bridge interface, it starts to learn mac's from nstreme1 interface.
Before the reset it only learns mac`s from the ethernet. The statistic of the nstreme1 is up, and becouse the nstreme has an IP Address, I can telnet the remote radio, but still the bridge
is not working.
2) I reset the bridge interface on the remote radio too, and starts to learn. After I complete the reset of the bridge on both radios it works OK. If I power on the radios I have to do the process again.
I here paste a bit of the configuration and the IOS version.
Please help me with this issue.
0 R
name="nstreme1" mtu=1500 mac-address=00:15:6D:63:22:3C arp=enabled disable-running-check=no tx-radio=wlan1 rx-radio=wlan2
remote-mac=00:15:6D:63:22:30 tx-band=5ghz tx-frequency=5805 rx-band=5ghz rx-frequency=5745 disable-csma=no
rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
ht-rates=1,2,3,4,5,6,7,8 ht-guard-interval=long ht-channel-width=20mhz ht-streams=single framer-policy=exact-size
framer-limit=4000
[admin@xxxx] /interface bridge port> print
Flags: X - disabled, I - inactive, D - dynamic
INTERFACE BRIDGE PRIORITY PATH-COST
0 nstreme1 bridge1 0x80 10
1 ether1 bridge1 0x80 10
[admin@xxxx] /system license> print
software-id: "98UP-FTT"
upgradable-to: v3.x
nlevel: 4
features:
Flags: X - disabled
NAME VERSION SCHEDULED
0 routeros-powerpc 3.0rc4
1 system 3.0rc4
2 routerboard 3.0rc4
3 X ipv6 3.0rc4
4 wireless 3.0rc4
5 ntp 3.0rc4
6 dhcp 3.0rc4
7 X hotspot 3.0rc4
8 X routing 3.0rc4
9 advanced-tools 3.0rc4
10 X security 3.0rc4
11 X ppp 3.0rc4
