Hello.
A created dual NSTREME ptp link with RB532+ CM9 but the troughput is only 9 Mbps fulldiplex… without any rules, routing adn queuing…
Where can be the problem ???
Hello.
you need to have a LOT of CPU power for Nstreme2 to get big speeds. 1Ghz or more
its all??? ![]()
what’s all ? yes, RB500 does not have enough power to be able to run Nstreme2 at high speeds
And what about WDS. I can`t create connection better than 21Mbps troughput. It is max or is possible to create better connection ? ![]()
You can enable Nstreme with WDS.
Normis, what obout the wireless test?
http://www.mikrotik.com/Documentation/wireless_test.pdf
Total tangent, but what the hey…
Yes, but not quite in the same way as vanilla 802.11. With Nstreme and WDS, it only makes sense to have a single “AP-bridge” with the rest using “station WDS” mode.
“AP-bridge” to “AP-bridge”, or “WDS slave” modes don’t work, as one would expect with a polling system.
So, with Nstreme, you can use WDS to get true bridging. However, you cannot use it as a “single antenna repeater”, as many seem to like to use WDS for.
–Eric
okay, then what do I do if I planned on using N-Streme and WDS to repeat a signal from an AP to a CPE?
