Dual Port Lan Card Issue
Hi i am new to this community and also MT
I already purchased 6 Level license and setup everything done by license dealer
Now i have issue with my LAN Cards (This is a guess)
I have 2 port PCI Lan card from Intel hardware is detect and working good but i have conflict with ip address both lan port hold different ip address
Port A : 192.168.1.1
Port B : 172.16.1.1
I can ping from Port A to Port B i mean from i can ping 192.168.1.1 from 172.16.1.1 even i unplug cable from 192.168.1.1 i think this is due to Lan Card issue
Please suggest me some solution
Can you post your config?
from where you need config?
Use the export command in the terminal and you can copy all of your settings.
problem solved.
Some where two connection was merged to one switch now i removed and fixed it
Awesome! Glad you were able to resolve it :smiley:
Just out of question
What dual LAN are you using?
Is it onbroad or PCI ?
Intel dual port and its PCI
but i resolved it
good :slight_smile: and cheers
