dual PPTP on same mikrotik with same gateway problem
I have a Mikrotik v2.9.40 using 2 PPTP links for Internet
ISP gives a private address as the next hop (192.168.180.1) for both these connections!
1 Link is the default internet link
2nd link is used for 2 remote users for VPN
How can I force packets to exit an interface WITHOUT specifying a gateway ?
cheers
kinglestat
I to have this same issue, did you ever work this out?
in 3.0 you can use interface routing without specifying an IP address.
Sam
