hey guys, i need some assistance with getting something set up (if what i’m thinking of is even possible). i hope this is posted in the right section…if not, please move as necessary.
at home i have 2 mikrotik routers, an RB493G is my main gateway AP/router, and an RB951G is connected behind it. the 951G is used to extend wireless coverage while at home, but will also occasionally serve as the main gateway/router while i am traveling, just like the 493G does at home.
the 951G is configured basically the same as the 493G, it has ether2-ether5 + wlan1 (2-9 + wlan1 on the 493G) assigned to a LAN bridge (let’s call it HOMEBRIDGE), which is masq’ed to a single WAN port (ether1). it has a DHCP Client on the WAN port, pulling a static DHCP lease assigned by the 493G. both devices have their own DHCP server assigned to their own HOMEBRIDGE, with each DHCP server using a different network (i.e., 493G uses 192.168.1.0/24, while the 951G uses 192.168.2.0/24).
what i want to do is set up the 951G so that when it is connected behind the 493G on my home network, trusted devices like my phone, laptop, etc. (based on the device’s MAC address) will bypass the 951G’s DHCP server & routing, and will instead be forwarded to the 493G’s DHCP server so that all my trusted devices are on the same network and can talk to each other. non-trusted devices (everything else) will use the DHCP server of the 951G and will be on a separate network.
however, if i am traveling and the 951G is the only device between me and the internet, i want all devices, trusted or not, to obtain a DHCP lease from the 951G’s DHCP server.
so basically it looks like this (excuse the MS Paint network diagram, although it should help visualize the idea i’m trying to convey
