Dual-Radio Client Mode
Hi!
Is it possible to use mikrotik-devices as client devices in dual-radio-environments?
The MT system should connect to a 5GHz AP with fallback to 2.4GHz AP as a standard-client does. How can I set this up?
Thank you
Regards,
Stril
Hi!
Isnt anybody using MT-Devices as client in Dual-Radio-environments?
Regards,
Connect to both network and add the routing for automatically fallback from router 1 to router 2 if 1 not work.
See for that the wik iand tons of examples.
He probably meant changing the band on one single ā€œ52ā€ type radio. This is unfortunately not implemented, only script can do it. But there is no way to detect whether the radio should be switched back to 5g band because when running on 2g it cannot make scan on 5g…
