Ok What the BEEP!!
I am trying to do the folowing:
4X Routerboard 532s (two RB52s each)
Router board radio config: (Same for all RB532s)
MikroTik WDS: SuperB,Nstream,WPA (Connection, access lists for all other RB WDS radios.)
MikroTik AP: B/G, open access.
The “main feed” router is set up in the folowing manor:
Ether1 = input,DHCP client, (gateway interface)
MikroTik-WDS = ap bridge, WDS mode = dynamic, default bridge = WDS Bridge, Nstream,WPA, connection list and access list for all other WDS router interfaces.
MikroTik AP: ap bridge, open access. (member of the WDS bridge via bridge menu (not under WDS in wireless)
(DHCP, DNS, etc all via the “feed router”)
Slave routers:
same config as the “main feed” router except I can only get the “slaves” to connect if they are set to “Station WDS” if I set them to “ap bridge” they will not even try to associate with any other device (feed router or other slaves)..
(All Ether 3s belong to the bridge group via bridge menu)
The issue is that I want to set up a “Mesh”, not a “Star”…
I will probably need to hop from one “slave to another” on one of the links..
I need to use one radio in each RB532 as a “mesh interface” and the other as an “AP interface”.. I want all inter router traffic on a 2.4Ghz (SuperG) WPA, Restriced Access Mesh backbone.
I need the other interface in each RB532 to run open 802.11B/G for client access.
The “Slave WDS” Vs the “ap bridge” seems to be the issue…
I am running 2.9.34, Routing test, RSTP test. (for rstp on the bridges.)
Help… I need to deploy this tommowow AM !!!
Thing that make you go Hmmmmmm…
Craig
