Dual Stack IPv6 Configuration
Hi Folks,
I’m needing some help configuring my Mikrotik to run a Dual Stack network with IPv4 and IPv6. My ISP has no free IPv4 addressed and just put everyone on CG-NAT since i use some remote tools to access my computer i need routable network. Besides running a VPN to an off country VPS i have the option to use the provided IPv6 but i cant get my head around it.
I did an extensive reading about IPv6 and understand the basics of it. First my ISP provides me with a /64 IP prefix. I had configured the modem/router from the ISP to create a DHCPv6 server, then on the mikrotik i configured a DHCPv6 client on my Mikrotik and got the prefix and IP address to my Mikrotik. Then added a pool named “internet” to that prefix.
Now my problem is to relay this prefix to my local network. I did create another DHCPv6 server on my mikrotik using the “internet” pool but the clients just get link local addresses (fe80) not public ones.
I’ve added an IP address to the local network then I was able to replicate SLAAC configuration from my ISP. Now my local machines have IPv6 addresses but everything is unreachable.
I’ve already added a firewall rule to allow all input,output and forward to and from ::/0 as a deseperated attemp and nothing. I’m almost removing the mikrotik and just using my ISP router… Waste of equipment.
Here is a sample config that may be helpful for a subscriber router from an article I did on IPv6 for ISPs
It sounds like you are almost there. Make sure you have assigned a subnet from the IPv6 prefix that’s delegated to the router. It needs to be on the interface/bridge that yourwired/wireless network is on
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-LAN
/interface vlan
add interface=ether1-WAN name=vlan1101-AP1-Data vlan-id=1101
/ip dhcp-client
add disabled=no interface=ether1-WAN
/ipv6 address
add eui-64=yes from-pool=home interface=ether2-LAN
/ipv6 dhcp-client
add add-default-route=yes interface=vlan1101-AP1-Data pool-name=home \
    pool-prefix-length=56 request=prefix
/ipv6 nd
add hop-limit=64 interface=ether2-LAN
/system identity
set name=Subscriber-1
/tool romon
set enabled=yes
For context, the full article is here.
https://stubarea51.net/2018/09/14/wisp-design-an-overview-of-adding-ipv6-to-your-wisp/
You wrote your ISP gave you a /64 prefix … what is RB’s WAN IPv6 address, is it from the assigned /64 prefix?
You can’t use addresses from the same /64 prefix both on WAN and LAN side of router.
That’s why normal ISPs hand-out larger prefixes (at least /60, mine gave me /56 even though they use PPPoE and WAN side uses link-local address) so client can easily configure their router …
Using smaller prefixes for subnets (e.g, /72) might be possible, but I’m not sure it’s widely supported ..
Smallest prefix for SLAAC is /64, so smaller ones are not the way to go.
