Dual WAN and multiple 2 internal netwoks issues
Hello All,
I’ve followed the following tutorials to setup my PCC WAN boding:
Scenario CRS109-8G-1S-2
WAN1=ether1
WAN2=ether2
Port Based VLAN Based on http://wiki.mikrotik.com/wiki/Manual:CRS_examples#InterVLAN_Routing
VLAN10 = 172.16.10.0/24
VLAN167 = 192.168.167.0/24
VLAN254 = 192.168.254.0/24
br-lan = vlan254, wlan3, ether6 bridged together
bond1 = ether7 and ether8 bobded as 802.3ad LACP to 3COM 4200 switch
Flags: X - disabled, R - running, S - slave
 #    NAME        MTU MAC-ADDRESS       ARP        MASTER-PORT      SWITCH
 0 X  ;;; UNE :: ether1
      WAN1       1500 4C:5E:XX:XX:F6:C4 enabled    none             switch1
 1 R  ;;; CLARO :: ether2
      WAN2       1500 4C:5E:XX:XX:F6:C5 enabled    none             switch1
 2 RS ;;; Clodstack Access Port 1
      ether3     1500 4C:5E:XX:XX:F6:C6 enabled    ether8           switch1
 3  S ;;; Cloudtsack Access Port 2
      ether4     1500 4C:5E:XX:XX:F6:C7 enabled    ether8           switch1
 4  S ;;; WiFi Hotspot Access Port
      ether5     1500 4C:5E:XX:XX:F6:C8 enabled    ether8           switch1
 5 RS ;;; Work Access Port
      ether6     1500 4C:5E:XX:XX:F6:C9 enabled    ether8           switch1
 6  S ;;; Trunk Port :: VLAN tagging
      ether7     1500 4C:5E:XX:XX:F6:CA enabled    none             switch1
 7 RS ;;; Trunk Port :: VLAN tagging
      ether8     1500 4C:5E:XX:XX:F6:CB enabled    none             switch1
 8    sfp1       1500 4C:5E:XX:XX:F6:CC enabled    none             switch1
For PCC I followed these:
http://wiki.mikrotik.com/wiki/Manual:PCC[url]
[url]https://aacable.wordpress.com/tag/mikrotik-howto-combine-multiple-wan-links/
https://aacable.wordpress.com/2011/07/27/mikrotik-dual-wan-load-balancing-using-pcc-method-complete-script-by-zaib/
it works fine for one LAN, but I’m facing the following issues
Please correct me if I’m wrong, but should I list all of my LAN interfaces here:
/ip firewall mangle
add action=mark-connection chain=input in-interface=WAN1 new-connection-mark=\
    WAN1_conn
add action=mark-connection chain=input in-interface=WAN2 new-connection-mark=\
    WAN2_conn
add action=mark-routing chain=output connection-mark=WAN1_conn \
    new-routing-mark=to_WAN1
add action=mark-routing chain=output connection-mark=WAN2_conn \
    new-routing-mark=to_WAN2
add chain=prerouting dst-address=192.168.1.0/24 in-interface=br-lan
add chain=prerouting dst-address=192.168.2.0/24 in-interface=br-lan
add action=mark-connection chain=prerouting dst-address-type=!local \
    in-interface=br-lan new-connection-mark=WAN1_conn \
    per-connection-classifier=both-addresses-and-ports:2/0
    in-interface=br-lan new-connection-mark=WAN2_conn \
    per-connection-classifier=both-addresses-and-ports:2/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
    in-interface=br-lan new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
    in-interface=br-lan new-routing-mark=to_WAN2
Whhen all rules are enabled I can’t ping a host on vlan10 from vlan254 and all hosts have internet access, qwhen I disable the last rule I can ping and access hosts on 172.16.10.0/24.
I saw a post where someone said to remove the in-interface, which I did with the same reult, also tried duplicating the rules, adding in-interface=“other VLAN”. Same result.
I’m in doubt what should I add for my inter-VLAN routing if the sub-interfaces, the master port (ether8) for Inter-VLAN access to work properly and for all vLANs have the benefit of the bonded WAN links?.
I’m new to these PCC rules but I’ve read the wiki to try to see wht I’m doing wrong but can’t spot what I’m doing wrong or missing.
Thanks.
