I seem to be missing something very basic.
Here is my setup :
MikroTik RouterOS 6.33.3
RB1100AHx2
I have a Dual WAN which has the same gateway, so I set it up using the below wiki.
http://wiki.mikrotik.com/wiki/Manual:Load_balancing_multiple_same_subnet_links
I then created a bridge1 and added ether3 to ether13 .
Setup DHCP for bridge 1
When I try to port forward none of it works :
/ip firewall nat add chain=dstnat dst-address=69.69.69.69 protocol=tcp dst-port=943
action=dst-nat to-addresses=192.168.1.101 to-ports=943
Where 69.69.69.69 is my external IP,
192.168.1.101 is the internal IP of a device connected to bridge 1.
943 is the port I want to forward.
