Dual WAN Balancing PCC and VPN Wireguard
Hello, help me figure out how VPN works with two providers. The goal is for clients to be able to choose which provider to connect to via Wireguard. I set up balancing through two providers according to this instruction.
https://wiki.mikrotik.com/wiki/Manual:PCC
The Internet works fine, access from outside to port forwarding, everything is ok. VPN works fine only when added to an exception in the PCC and works only on the default provider. Is it possible to somehow mark incoming and outgoing packets on a vpn connection in the same way as for a local network?
