Dual WAN Bonding + DHCP Server Enabled
Hello Guys,
I am Completely New to MikroTik world, and basically have some very Basic IT knowledge but not intermediate level, i am Trying to set my my MikroTik RouterBoard 750GL trying to do bonding and Wan Failover setup, I searched Several Google Pages and Tried they all work, but i am only able use both Bandwidth from two Wan for first few minutes, and than later it only uses bandwidth one one LAN, i will Explain below my Setup.
WAN1= 8mbps Line Subscription & provides me about 7.2mbps actually. (Using With Linksys Cisco X3500 ADSL Modem)
With Gateway: 192.168.1.1
WAN2= 4mbps Line Subscription but provides me between 6.2mbps ~ 7.2mbps actually ( Using ZTE ADSL modem)
With Gateway: 192.168.2.1
My ports Setup as Follow:
MikroTik 750GL (Webinterface 6.22)
Port 1 = Local (Gateway: 192.168.0.1)
Port 2 = WAN1 (Gateway: 192.168.1.1)
Port3 = WAN2 (GateWay: 192.168.2.1)
I am Trying to use load balancing and trying to prevent fail over as well, Initially when i setup the Router Board it provides me combined speed of Approximate 14mbps ( which seems to be alright by 7+7 mbps= 14) but after 3 or 4 minutes on will only use one WAN and other remains connoted and shows running but no data packets are pulled during download, and not always it drops one particular WAN, some time it will not use bandwidth from WAN1 and some times from WAN2.
DHCP Server Enabled on Local :
And Complete Tested and relaible Script will be very highly Appreciated.
Regards
Hasham
