We have a specific usage case for dual WAN VLAN tagged traffic with two DHCP servers & LLDP med. I’ve got some experience with Juniper devices but having a hard time finding a working config for Mikrotik.
We are using the RB2011UiAS-2HnD-IN
I would like to use Ether1 as a master port with two VLAN’s VLAN 1100 which will have a public IP for data, and VLAN 1101 which will have a private vlan for VoIP traffic. Ports 2-8 will be DHCP ideally with LLDP-MED enabled to hand out an internal to phones VLAN 100 for data (default) and 200 for voip. A DHCP would sit on the data side issuing internal IP’s and natting out VLAN 1100’s public IP and the DHCP server on vlan 200 would be handing out a DHCP pool without nat out the IP on VLAN 1101. We have static routes for a /26 or /24 at each site on the voip vlan to route to the VLAN 1101 IP assigned. We would also like to remask DSCP & 802.1p outgoing on VLAN 1100 to DSCP 00 VLAN priority 0 and outgoing on VLAN1101 to DSCP 46 vlan priority 6.
Would anyone be kind enough to point me on the right way or let me know a good estimate on what I could expect to pay for freelance help?
Thanks,
Tim
