Hi at all,
i would like to use to Wan Connections:
Szenario:
Wan DSL Static IP Ether1
Wan PPPOE Ether5
2 Vlan´s with DHCP Subnet
10.0.0.0/22 Guest
192.168.0.0/24 Privat
The Guest should go to the Inetnet over PPPOE Ether5 and the Privat over Ether1.
If i try to Mas. in IP Firewall 10.0.0.0/22 to 0.0.0.0/0 Out PPOE Interface it doesn´t work.
If i use only Out PPPOE Interface it works fine, but if i add a rule for the Privat Subnet it doesnt work again.
Could you please gave a Tip!
Thanks a lot
