If this has been covered already, sorry in advance.
I am trying to configure a Dual WAN (DHCP, PPPoE) solution with PCC load balancing that is accessible by 3 local networks (untagged LAN and 2 VLANs)
I have the wireless/LAN networks routing over either WAN okay, but am having problems getting the PCC load balancing to work. Here is what I have so far:
/ip firewall mangle
add chain=input in-interface=wan1 action=mark-connection new-connection-mark=wan1_conn
add chain=input in-interface=wan2 action=mark-connection new-connection-mark=wan2_conn
add chain=output connection-mark=wan1_conn action=mark-routing new-routing-mark=to_wan1
add chain=output connection-mark=wan2_conn action=mark-routing new-routing-mark=to_wan2
add chain=prerouting dst-address-type=local action=accept in-interface=lan1
add chain=prerouting dst-address-type=local action=accept in-interface=lan2
add chain=prerouting dst-address-type=local action=accept in-interface=lan3
add chain=prerouting dst-address-type=!local in-interface=lan1 per-connection-classifier=both-addresses-and-ports:2/0 action=mark-connection new-connection-mark=wan1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=lan1 per-connection-classifier=both-addresses-and-ports:2/1 action=mark-connection new-connection-mark=wan2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=lan2 per-connection-classifier=both-addresses-and-ports:2/0 action=mark-connection new-connection-mark=wan1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=lan2 per-connection-classifier=both-addresses-and-ports:2/1 action=mark-connection new-connection-mark=wan2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=lan3 per-connection-classifier=both-addresses-and-ports:2/0 action=mark-connection new-connection-mark=wan1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=lan3 per-connection-classifier=both-addresses-and-ports:2/1 action=mark-connection new-connection-mark=wan2_conn passthrough=yes
add chain=prerouting connection-mark=wan1_conn in-interface=lan1 action=mark-routing new-routing-mark=to_wan1
add chain=prerouting connection-mark=wan2_conn in-interface=lan1 action=mark-routing new-routing-mark=to_wan2
add chain=prerouting connection-mark=wan1_conn in-interface=lan2 action=mark-routing new-routing-mark=to_wan1
add chain=prerouting connection-mark=wan2_conn in-interface=lan2 action=mark-routing new-routing-mark=to_wan2
add chain=prerouting connection-mark=wan1_conn in-interface=lan3 action=mark-routing new-routing-mark=to_wan1
add chain=prerouting connection-mark=wan2_conn in-interface=lan3 action=mark-routing new-routing-mark=to_wan2
add dst-address=0.0.0.0/0 gateway=wan1 routing-mark=to_wan1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=wan2 routing-mark=to_wan2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=wan1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=wan2 distance=2 check-gateway=ping
wan1 & wan2 are my WAN interfaces
lan1, lan2, lan3 are bridges joining the LAN/VLANs with their respective AP/VirtualAPs
Any thoughts/input is greatly appreciated.
Cheers
