Hello
I have a mikrotik router (v6.46) with 2 wan access :
- 1 SDSL with static ip address (router 185.1.1.211, gateway 185.1.1.210)
- 1 ADSL with pppoe dialer (add default route cheecked).
I’m trying to access the router from WAN on its public addresses.
I’ve created mangle rules to mark incming trafic on these interfaces :
/ip firewall mangle
add action=mark-routing chain=prerouting in-interface=ether1-SDSL new-routing-mark=route_via_sdsl passthrough=no
add action=mark-routing chain=prerouting in-interface=pppoe-adsl new-routing-mark=route_via_adsl passthrough=no
Then I created routes for these routing marks :
add check-gateway=ping distance=1 gateway=185.1.1.210 pref-src=185.1.1.211 routing-mark=route_via_sdsl
add distance=1 gateway=pppoe-adsl routing-mark=route_via_adsl
the default route in the main routing table is pppoe-adsl.
and I created 2 routing rules too :
/ip route rule
add routing-mark=route_via_sdsl table=route_via_sdsl
add routing-mark=route_via_adsl table=route_via_adsl
- when I ping IP of the pppoee dialer from wan, everything work as expected (ping received on pppoe-adsl, reply sent from pppoe-adsl with pppoe-adsl as source address
- when I ping IP of the SDSL interface from wan, everything work as expected (ping received on SDSL interface, reply sent from SDSL interface with 185.1.1.211 as source address
My problem is that when I try to access the router via web :
- when I access it on pppoe-adsl IP address, replies are sent from pppoe-interface with pppoe-interface address as source address
- when I acces it on SDSL IP address, replies are sent from pppoe-interface with SDSL ip address as source address
[user@rtr] /tool sniffer> packet print
# TIME INTERFACE SRC-ADDRESS DST-ADDRESS IP-PROTOCOL SIZE CPU FP
3 0.258 ether1-SDSL 80.13.x.x:49729 185.1.1.211:80 (http) tcp 479 0 no
4 0.258 pppoe-adsl 185.1.1.211:80 (http) 80.13.x.x:49729 tcp 52 0 no
As I’m accessing the router on its WAN addresses, I guess there’s no nat rules involved. Firewall rules are OK here (accept all).
AM I doing something wrong or does it look like a bug ?
Regards
