I have a small remote network using a RB750 as the head end router. There are two WAN sources - one a 26 mile wireless link (primary) and a Verizon LTE link handled by a Cradlepoint IBR650 (secondary).
Currently, the Cradlepoint is connected to ETH1 on the RB750. The Cradlepoint is managing the wireless link as primary and the LTE link as failover and is working OK (it can accept an external WAN source as well as using its internal LTE modem).
While I am getting by with this, I would rather have the RB750 accept both WAN sources and manage failover. The 650 is kinda a “black box” and doesn’t allow for a lot of flexibility in its configuration. Specifically, when it is operating in passthrough mode (like a bridge), it isn’t doing any routing and therefore won’t allow a src-nat rule that will allow me to access the wireless link devices so I can administer them. The 750 does this fine.
I have paged through lots of Mikrotik dual-WAN setups online and to say the least, am confused. Use NETWATCH, don’t use it, use a script, just use route commands…lots of different ways to go here.
Here is what I would like to be able to do:
Have my primary wireless feed connected to ETH1 on the 750 and the LTE feed via the Cradlepoint on ETH2 (unless this doesn’t make sense - I am open to suggestions).
Ping out on ETH1 to 8.8.8.8 (or whatever) to check for connectivity. If pings fail after some set period, switch to LTE on ETH2. When connectivity is restored on ETH1 (verifying by pings again), switch back.
I need to know how to change my current config to accept two WAN sources and then implement the failover scheme above. Again, I am open to suggestions on the scheme - I will readily admit that this isn’t my field of expertise. Because of that, simpler is better.
Here’s my current interface scheme:
[admin@MikroTik] > interface print
NAME TYPE ACTUAL-MTU L2MTU
0 R ether1-gateway ether 1500 1598
1 RS ether2-master-local ether 1500 1598
2 RS ether3-slave-local ether 1500 1598
3 RS ether4-slave-local ether 1500 1598
4 RS ether5-slave-local ether 1500 1598
5 R ;;; created from master port
bridge1 bridge 1500 1598
[admin@MikroTik] >
I would appreciate some help here as to what to change (and how) that won’t break everything else the router is doing. What will happen if ether2 becomes another gateway and ether3 becomes the “master”? Will all other router functions continue as before?
I am sure most of this is just basic stuff, but as I said before, I am no expert.
Thanks in advance for any help on this.
