Dual WAN fasttrack issue
Hi guys,
I was searching something about fasttrack issues (slow connection) with dual wan, I found a lot of cases, but with no solutions.
In my case, I disabled the fasttrack rule and everything is fine, but CPU usage got higher. Im supposing to use this way, but is there something to fix this scenario? (Dual WAN (only fail over) + fast track)
Thanks in advance.
Fasttrack do a bypass on firewall and queue rules. How you need to mark the connection with mangle, fasttrack will don’t leave the marking occur.
The more firewall rules and queues, more will be used the cpu, so you need to optimize the firewall.
https://wiki.mikrotik.com/wiki/Tips_and_Tricks_for_Beginners_and_Experienced_Users_of_RouterOS#If_something_does_not_work.2C_then_maybe_it_is_like_that_on_purpose
What is your internet speed?
If is a “big” speed like >= 150Mbps, is normal the cpu usage be high when has various firewall rules (if the router is a mipsbe).
Actually, 50Mbps + 120Mbps… I’m testing two ISPs, but it will not take higher than 200Mbps.
I do need some mangle marks, so, there’s no way, I’ll maintain fasttrack disabled.
Thanks for the link, I’m going to optimize my firewall rules. To be honest, I’m actually using the rules created by default on first setup. Is it good enough?
I have stumbled these days upon exactly the same issue! (Although after loosing almost half a day looking in all the wrong places…)
However I did manage to “squeeze” almost 500 Mib out of a hEX router (RB750Gr3 running the latest 6.41.2), by using two ISP’s both providing 300 Mib download, load-balancing between them, and using NAT.
Profiling the system with
/tool profile cpu=all freeze-frame-interval=6
yields that almost 30-40% is spent in network and 40-50% in firewall.
In order to obtain this bandwidth I played a lot with the firewall rules, and currently I applied the following pattern:
  • for the forwarding chain in filter I have created a new chain forwarding-new where I jump-to for all packets matching connection-state=new; herein I put all my actual forwarding rules;
  • for the prerouting chain in mangle I have created a new chain prerouting-mark where I jump-to for all packets matching connection-state=new; herein I put all my connection marking rules, making sure to always use connection-mark=no-mark as a precondition and passthrough=yes;
  • in the prerouting chain in mangle the mark-routing=... rules all have passthrough=no;
By using this setup the typical packet has to pass only through a few rules, especially in the mangle table.
I have also made the following observations:
  • although the forwarding chain of filter has as the first rule an action=accept for connection-state=established,related, without resorting to my forwarding-new chain the performance drops almost by 50%;
  • yesterday I managed to get almost 600 Mib (i.e. the maximum allowed by the two ISP’s combined), but for some reason I can’t replicate that anymore…
  • the limit I managed to get today (i.e. 500 Mib) by taking into account that the actual traffic passing through the router is twice as much (i.e. 500 client->router and another 500 router->ISP) I was wondering if I didn’t somehow managed to get into a hardware limitation of the hEX router?
  • I have yet to find an “optimum” and “simple” way to express load-balancing rules in mangle
  • for some reason using routing rules that have action=lookup-only-in-table also helps with performance…
For reference bellow are my rules (disabled rules are prefixed with #):
/interface list member add interface=ether2-vlan1 list=lan
/interface list member add interface=ether2-vlan3 list=lan
/interface list member add interface=pppoe-out1 list=wan
/interface list member add interface=pppoe-out2 list=wan
/ip firewall address-list add address=172.30.163.0/24 list=local
/ip firewall address-list add address=172.30.214.0/24 list=local
# /ip firewall filter add action=accept chain=forward comment="forward accept all" disabled=yes
# /ip firewall filter add action=fasttrack-connection chain=forward connection-state=established,related disabled=yes
/ip firewall filter add action=accept chain=forward connection-state=established,related
/ip firewall filter add action=jump chain=forward connection-state=new jump-target=forward-new
/ip firewall filter add action=accept chain=forward-new in-interface=ether2-vlan1 out-interface-list=lan src-address=172.30.214.0/24
/ip firewall filter add action=accept chain=forward-new in-interface=ether2-vlan1 out-interface-list=wan src-address=172.30.214.0/24
# /ip firewall filter add action=accept chain=forward-new in-interface=ether2-vlan1 disabled=yes
/ip firewall filter add action=accept chain=forward-new in-interface=ether2-vlan3 out-interface-list=lan src-address=172.30.163.0/24
/ip firewall filter add action=accept chain=forward-new in-interface=ether2-vlan3 out-interface-list=wan src-address=172.30.163.0/24
# /ip firewall filter add action=accept chain=forward-new in-interface=ether2-vlan3 disabled=yes
/ip firewall filter add action=drop chain=forward connection-state=invalid
/ip firewall filter add action=drop chain=forward in-interface=ether1
/ip firewall filter add action=drop chain=forward in-interface=pppoe-out1
/ip firewall filter add action=drop chain=forward in-interface=pppoe-out2
# filter rules for input and output are not listed
/ip firewall mangle add action=jump chain=prerouting connection-state=new jump-target=prerouting-mark
/ip firewall mangle add action=jump chain=postrouting connection-state=new jump-target=postrouting-mark
# whatever enters or exits a WAN interface and is not marked are "pinned" on that interface
/ip firewall mangle add action=mark-connection chain=prerouting-mark connection-mark=no-mark in-interface=pppoe-out1 new-connection-mark=con-x11 passthrough=yes
/ip firewall mangle add action=mark-connection chain=prerouting-mark connection-mark=no-mark in-interface=pppoe-out2 new-connection-mark=con-x12 passthrough=yes
/ip firewall mangle add action=mark-connection chain=postrouting-mark connection-mark=no-mark new-connection-mark=con-x11 out-interface=pppoe-out1 passthrough=yes
/ip firewall mangle add action=mark-connection chain=postrouting-mark connection-mark=no-mark new-connection-mark=con-x12 out-interface=pppoe-out2 passthrough=yes
# randomly assign new connections to one of the two WAN's
/ip firewall mangle add action=mark-connection chain=prerouting-mark connection-mark=no-mark dst-address-list=!local dst-address-type=!local in-interface-list=lan new-connection-mark=con-x11 passthrough=yes random=50 src-address-list=local
/ip firewall mangle add action=mark-connection chain=prerouting-mark connection-mark=no-mark dst-address-list=!local dst-address-type=!local in-interface-list=lan new-connection-mark=con-x12 passthrough=yes src-address-list=local
# traffic entering via WAN is always accepted (i.e. no need to mark it)
/ip firewall mangle add action=accept chain=prerouting in-interface=pppoe-out1
/ip firewall mangle add action=accept chain=prerouting in-interface=pppoe-out2
# here we mark forwarded packets (i.e. generated from the cliens)
/ip firewall mangle add action=mark-routing chain=prerouting connection-mark=con-x12 in-interface-list=lan new-routing-mark=gw-x12 passthrough=no
/ip firewall mangle add action=mark-routing chain=prerouting connection-mark=con-x11 in-interface-list=lan new-routing-mark=gw-x11 passthrough=no
# here we mark output packets (i.e. generated from the router itself);  note no load-balancing is done for the router generated traffic
/ip firewall mangle add action=mark-routing chain=output connection-mark=con-x11 new-routing-mark=gw-x11 passthrough=no
/ip firewall mangle add action=mark-routing chain=output connection-mark=con-x12 new-routing-mark=gw-x12 passthrough=no
/ip route add check-gateway=ping distance=7 gateway=pppoe-out1
/ip route add check-gateway=ping distance=7 gateway=pppoe-out1 routing-mark=gw-x11
/ip route add check-gateway=ping distance=7 gateway=pppoe-out2
/ip route add check-gateway=ping distance=7 gateway=pppoe-out2 routing-mark=gw-x12
# note the duplicated routes for LAN's
/ip route add distance=1 dst-address=172.30.163.0/24 gateway=ether2-vlan3 routing-mark=gw-x11
/ip route add distance=1 dst-address=172.30.163.0/24 gateway=ether2-vlan3 routing-mark=gw-x12
/ip route add distance=1 dst-address=172.30.214.0/24 gateway=ether2-vlan1 routing-mark=gw-x11
/ip route add distance=1 dst-address=172.30.214.0/24 gateway=ether2-vlan1 routing-mark=gw-x12
/ip route rule add action=lookup-only-in-table routing-mark=gw-x11 table=gw-x11
/ip route rule add action=lookup-only-in-table routing-mark=gw-x12 table=gw-x12
I hope it helps, and I hope a more “optimal” solution is found!
P.S.: For some reason the Mikrotik forum doesn’t “like” traffic load-balanced… :slight_smile:
Thank you so much! This has been the best tutorial of all the other ones I have tried.
For you, the reason the forum doesn't like it load-balanced is because it breaks the HTTPS connection. I force all my HTTPs connections out my more stable (but slow) interface:
/ip firewall mangle
add chain=prerouting action=mark-connection new-connection-mark=WAN2_conn passthrough=yes protocol=tcp dst-address-type=!local connection-mark=no-mark in-interface=bridge dst-port=443 log=no log-prefix=""
add chain=prerouting action=mark-connection new-connection-mark=WAN2_conn passthrough=yes protocol=udp dst-address-type=!local connection-mark=no-mark in-interface=bridge dst-port=443 log=no log-prefix=""
I have other routing going on, and I am using recursive routing to monitor my WANs, so now even if something is broken in my ISP (but my link stays up), it will no longer use that link.
Thanks so much! I will definitely share when I finish my tweaking, which would have mostly your firewall rules and my routing.
Edit: For others running his scripts above, you should capitalize WAN and LAN for the interface lists. I broke access from my network to the world because it (lan) was lowercase, and the router still had a dropall if not coming from LAN (as opposed to lan)
Struggled with this almost whole day today until thinked about fasttrack. I have to direct some special connections from LAN through backup WAN. I tried to do it with common multi-WAN mangle rulles but had encountered very low bandwidth (obviously due to massive packet loss).
After all my solution is not to disable fasttrack connection rule but is to setup it with “connection-mark=no-mark” condition. Seems to work fine since it works and majority of my connections have no marks. But multiple fasttrack rules don’t work.
