dual WAN for newbies
Hi
supernew to mikrotik - got a CCR1009-7G-S-S±PC (used peplink balance one core before that, till i hit the 400mbps limitation)
setting up single WAN with NAT surprisingly required some time but i am past that and happy.
really love CLI over SSH (not a fan of Winbox especially given my main laptop is mac)
so want to set up dualWAN (and play with different ways of load balancing it PCC, firewall marking etc trying to understand what are the pros/cons and how can i configure it for my needs with weighted/priority outbound rules and not break any sensitive protocols like https,udp+voip,etc)
but as a first basic step want to test simple failover: use WAN1 and if it fails fallback to WAN2, but once WAN1 is back online switch to it
so couple of questions
  1. is there a ping only method to check if connection is alive, i am used to dns query check - like it more
  2. so lot of different instructions are rather simple but all have explicit gateway commands like
/ip route add gateway=192.168.1.1 check-gateway=ping
/ip route add gateway=192.168.2.1 distance=2
but both my connections are dynamic public IP:
WAN1: /ip dhcp-client add interface=ether1 disabled=no
WAN2: /interface pppoe-client add disabled=no interface=combo1 user=xxxxxxx password=xxxxxxx add-default-route=yes use-peer-dns=yes
so how should i proceed if i want to add those properties into dhcp WAN(check-gateway=ping) and distance=2 into pppoe obtained gateway
ok i learned both has options to add distance, but not the check-gateway thing.
for dhcp lease it seems there is a script you can run after lease changes (where i can add gateway manually and do any other stuff)
but for pppoe establishing there is no script option - is there a way to have custom script run on interface created/destroyed?
Or given i still run check ping script to check both connection and adjust routing tables/kill connections on any change - i can also test if pppoe exists before trying to ping through it?
Read through this topic lots of good learning…
http://forum.mikrotik.com/t/advanced-routing-failover-without-scripting/136599/140
http://forum.mikrotik.com/t/moving-from-fail-over-to-using-both-wans/143145/2
