There is RB951 with ROS 5.25 connected to 2 ISP’s.
How to send answers to external requests (icmp, ssh, winbox, …) via the same WAN interface?
Following does not work:
add dst-addr=0.0.0.0/0 gateway=1.1.1.1 distance=10 routing-mark=route-isp1
add dst-addr=0.0.0.0/0 gateway=2.2.2.2 distance=10 routing-mark=route-isp2
add dst-addr=0.0.0.0/0 gateway=1.1.1.1 distance=20
add dst-addr=0.0.0.0/0 gateway=2.2.2.2 distance=30
/ip firewall mangle
add action=mark-connection chain=prerouting connection-mark=no-mark \
in-interface=ether-isp1 new-connection-mark=conn-isp1 passthrough=yes
in-interface=ether-isp2 new-connection-mark=conn-isp2 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=conn-isp1 new-routing-mark=route-isp1 passthrough=no
add action=mark-routing chain=prerouting connection-mark=conn-isp2 new-routing-mark=route-isp2 passthrough=no
add action=mark-routing chain=output connection-mark=conn-isp1 new-routing-mark=route-isp1 passthrough=no
add action=mark-routing chain=output connection-mark=conn-isp2 new-routing-mark=route-isp2 passthrough=no
Thanx in advance!
efaden
January 20, 2014, 1:34am
2
SpaceCommander:
/ip firewall mangle
Thanx in advance!
Look at http://mum.mikrotik.com/presentations/US12/tomas.pdf
If you read through that and can’t get it to work I can try to write out the config for you.
-Eric
Okay, fixed firewall mangle settings are now here (“prerouting” changed to “input”, as on Tomas slides 31,32):
add action=mark-connection chain=INPUT connection-mark=no-mark \
But it still does not work..
