I am having Two WAN and Two LAN
IP Config: Wan1 : 192.168.50.100
Wan2 : 192.168.3.200
LAN1 : 192.168.1.1
LAN2: 192.168.2.1
Both the WAN are active but all internet traffic is routing from wan1. port forwarding on both LAN1 192.168.1.25:88 from WAN1 and on LAN 2 : 192.168.2.23:88 From WAN2 . I am only able to access from WAN1. When i disable routing from WAN1 the all internet traffic start from WAN2 and port forwarding on LAN2 start working.
I need to know what should i do my both the WAN be operational and internet traffic route from WAN1 and both port forwarding also work , if user come from WAN2 if get access on LAN2 IP and if user comes from LAN1 could access from LAN1. some configuration setting is attached image
Ahsan
