Dual wan load balancing failover help
I want to configure my mikrotik with 2 ISP and 1 Lan with load balancing but i need to ping IP from both of them and form ISP1 and from ISP 2 with LAN
For example
ISP 1: ETH1 : 192.168.1.0/24
ISP 2 :ETH2 :170.22.1.0/24
LAN :ETH3 :20.20.20.1/24
I configure with loadbalancing but when i want to ping IP from ISP 1 i cant ping and the same situation from ISP2.
From lan i want to ping 192.168.5.1 and for example 170.22.8.1. How can i configure ore what protocol can i follow to make this configuration.
Thank you!
