Dual Wan Load Balancing (PCC) 1 PPPoe Dynamic IP + 1 Static IP
Dear Sirs,
I’ve been playing around with Dual Wan and looking for many scripts online but I’m really lost. There’s too many options but which suits my case.
DHCP is on with pool 192.168.0.100-192.168.0.254
WAN1 : PPPoe ( Dynamic IP) Port Name: pppoe-DialUp / ether1-gateway
WAN2: 192.168.10.1 (Static IP) Port Name: ether5-slave-local
Plz check this script will it work properly?
/interface bridge settings
set use-ip-firewall=yes
set use-ip-firewall-for-pppoe=yes
/ip firewall mangle
add chain=prerouting dst-address=192.168.0.0/24 in-interface=bridge-local action=accept
/ip firewall mangle
add chain=input  in-interface=pppoe-DialUp connection-mark=no-mark action=mark-connection new-connection-mark=WAN1 passthrough=no
add chain=input  in-interface=ether5-slave-local connection-mark=no-mark action=mark-connection new-connection-mark=WAN2 passthrough=no
/ip firewall mangle
add chain=output  out-interface=pppoe-DialUp connection-mark=WAN1 action=mark-routing new-routing-mark=WAN1 passthrough=no
add chain=output  out-interface=ether5-slave-local connection-mark=WAN2 action=mark-routing new-routing-mark=WAN2 passthrough=no
/ip firewall mangle
add chain=prerouting connection-mark=no-mark dst-address-type=!local  in-interface=bridge-local per-connection-classifier=both-addresses:2/0  action=mark-connection new-connection-mark=WAN1
add chain=prerouting connection-mark=no-mark dst-address-type=!local  in-interface=bridge-local per-connection-classifier=both-addresses:2/1  action=mark-connection new-connection-mark=WAN2
/ip firewall mangle
add chain=prerouting  connection-mark=WAN1 in-interface=bridge-local action=mark-routing new-routing-mark=WAN1  passthrough=no
add chain=prerouting  connection-mark=WAN2 in-interface=bridge-local action=mark-routing new-routing-mark=WAN2  passthrough=no
add dst-address=0.0.0.0/0  gateway=pppoe-DialUp routing-mark=WAN1
add dst-address=0.0.0.0/0  gateway=ether5-slave-local routing-mark=WAN2
add dst-address=0.0.0.0/0  gateway=pppoe-DialUp distance=1
add dst-address=0.0.0.0/0  gateway=ether5-slave-local distance=2
Example for dynamic IPs:
add chain=src-nat  out-interface=pppoe-DialUp action=masquerade
add chain=src-nat  out-interface=ether5-slave-local action=masquerade
Example for static IPs of 1.2.3.4 and 4.3.2.1:
add chain=src-nat  out-interface=pppoe-DialUp action=src-nat to-addresses=1.2.3.4
add chain=src-nat  out-interface=ether5-slave-local action=src-nat to-addresses=4.3.2.1
Example for dynamic/Static IPs:
add chain=src-nat  out-interface=ether5-slave-local action=src-nat to-addresses=192.168.10.2
Or shall I go with this script?
#|/ip address
/ip address add address=192.168.10.2/24 network=192.168.10.0 broadcast=192.168.10.255 interface=ether2
/ip address add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=ether5 comment="default configuration"
#|/ip firewall mangle
/ip firewall mangle add chain=input in-interface=pppoe-out1 action=mark-connection new-connection-mark=ether1_conn
/ip firewall mangle add chain=input in-interface=ether2 action=mark-connection new-connection-mark=ether2_conn
/ip firewall mangle add chain=output connection-mark=ether1_conn action=mark-routing new-routing-mark=to_ether1
/ip firewall mangle add chain=output connection-mark=ether2_conn action=mark-routing new-routing-mark=to_ether2
/ip firewall mangle add chain=prerouting dst-address=192.168.1.0/24 action=accept in-interface=ether5
/ip firewall mangle add chain=prerouting dst-address=192.168.10.0/24 action=accept in-interface=ether5
/ip firewall mangle add chain=prerouting dst-address-type=!local in-interface=ether5 per-connection-classifier=both-addresses-and-ports:2/0 action=mark-connection new-connection-mark=ether1_conn passthrough=yes
/ip firewall mangle add chain=prerouting dst-address-type=!local in-interface=ether5 per-connection-classifier=both-addresses-and-ports:2/1 action=mark-connection new-connection-mark=ether2_conn passthrough=yes
/ip firewall mangle add chain=prerouting connection-mark=ether1_conn in-interface=ether5 action=mark-routing new-routing-mark=to_ether1
/ip firewall mangle add chain=prerouting connection-mark=ether2_conn in-interface=ether5 action=mark-routing new-routing-mark=to_ether2
#|/ip route
/ip route add dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-mark=to_wan1 check-gateway=ping
/ip route add dst-address=0.0.0.0/0 gateway=192.168.10.1 routing-mark=to_ether2 check-gateway=ping
/ip route add dst-address=0.0.0.0/0 gateway=pppoe-out1 distance=1 check-gateway=ping
/ip route add dst-address=0.0.0.0/0 gateway=192.168.10.1 distance=2 check-gateway=ping
#|/ip firewall nat
/ip firewall nat add chain=srcnat out-interface=pppoe-out1 action=masquerade
/ip firewall nat add chain=srcnat out-interface=ether2 action=masquerade
#| DHCP server is on switch, with address pool 192.168.0.100-192.168.0.200
/ip pool add name=default-dhcp ranges=192.168.0.100-192.168.0.200
/ip dhcp-server add name=default address-pool=default-dhcp interface=ether5 disabled=no
/ip dhcp-server network add address=192.168.0.0/24 gateway=192.168.0.1 dns-server=192.168.0.1 comment="default configuration"
#| DNS
/ip dns set allow-remote-requests=yes
/ip dns static add name=router address=192.168.0.1
#| Now Configure DNS server so users can resolve hostnames,
#| Ex.cache-size=5000KiB
#| DNS Google = 8.8.8.8,8.8.4.4
#| DNS 3BB = 110.164.252.222,110.164.252.223
/ip dns set allow-remote-requests=yes cache-max-ttl=1w cache-size=5000K max-udp-packet-size=512 servers=8.8.8.8,8.8.4.4
For the unequal-speed Internet line, you can edit the code (for example speed WAN 1,2,3 4Mb speed WAN 4 and 8 Mb).
(The principle is, in the first iteration has many times. Shared Bandwidth just trying to use it as well. Or may be offset to some Link as special needs or not.
- In the first sample loops are five times 4/0 to 4/4 by trying to spread out through Link Bandwidth used all the same).
add chain = prerouting dst-address-type =! local in-interface = Local per-connection-classifier = both-addresses-and-ports: 4/0 action = mark-connection new-connection-mark = ether1_conn passthrough = yes.
add chain = prerouting dst-address-type =! local in-interface = Local per-connection-classifier = both-addresses-and-ports: 4/1 action = mark-connection new-connection-mark = ether2_conn passthrough = yes.
add chain = prerouting dst-address-type =! local in-interface = Local per-connection-classifier = both-addresses-and-ports: 4/2 action = mark-connection new-connection-mark = ether3_conn passthrough = yes.
add chain = prerouting dst-address-type =! local in-interface = Local per-connection-classifier = both-addresses-and-ports: 4/3 action = mark-connection new-connection-mark = ether4_conn passthrough = yes.
add chain = prerouting dst-address-type =! local in-interface = Local per-connection-classifier = both-addresses-and-ports: 4/4 action = mark-connection new-connection-mark = ether4_conn passthrough = yes.
I recommend copying the code stored as Word, because if you want to change the IP or the other. We can use the search function and replace it.
This line confused me in the second script what shall I put for the PPPoe as it’s a dynamic instead the (dst-address=192.168.1.0/24) ?
I added a photo for my interfaces.
Without having read your whole scripts, I recommend to follow these instructions:
http://wiki.mikrotik.com/wiki/Manual:PCC#Application_Example_-_Load_Balancing
I implemented it this way with good results.
the article above is talking for 2 dsl lines with dhcp. is not the same for 1 pppoe and 1 dhcp.
i have also the same question regarding second senario. the same line confusing me also when i have first line with pppoe (bridge modem) and second line with dhcp.
for the moment in a case with pppoe and dhcp i am using the first script and is working good. i dont know why “use-ip-firewall=yes” is needed.
i found the article for 2 pppoe in the link below and is very good. also similar to yours for the first senario.
https://blog.linitx.com/load-balancing-multiple-internet-connections/
In fact it is not even talking about DHCP. It only relies on Interfaces. So which point in the article do you think will not work with pppoe interfaces?
Of course you don´t have to add the WAN ip address manually but you don´t have to do with dhcp also.
so you mean this line is not needed?
or what needed for 1 pppoe and 1 dhcp?
No I meant these lines:
/ ip address
add address=10.111.0.2/24 network=10.111.0.0 broadcast=10.111.0.255 interface=ISP1
add address=10.112.0.2/24 network=10.112.0.0 broadcast=10.112.0.255 interface=ISP2
Go through the Explanation section and read each paragraph and build it step by step. It is really nice explained.
Either you are willing to put some effort and brains in it or you consult a technican that implements it for you. The forum is for answering questions but not for claiming adapted comprehensive solutions.
Additional benefit is: If you are complete with your solution, you understood what you were doing and can adjust it later, make some extensions or find faults.
Guys, I read too many scenarios thus now I’m having issues with 6.31.. I’m not into scripting :frowning:
This section is for beginners basics no ? All I’ve asked is for your help! I’ve found too many scenarios 2wan or 3 or 4 + failovers ects..static dynamic but I haven’t found one that fits my need ! I’ve collected too many scripts and so far it didn’t work for me.
Wan1 is PPPoe (Dynamic) - Wan2 Static ip… My routers ports 2 to 5 are bridged.. All tutorials shows no bridge…
Kindly help me out.
Regards,
freemannnn,
Your suggestion didn’t work out with me:
/ip firewall mangle
/ip firewall mangle
/ip firewall mangle
/ip firewall mangle
/ip firewall mangle
The posted PCC configuration can be adapted to bridge very simple. Change in-interface=LAN to in-interface=your-bridge and so on.
this is the script i am using…
pppoe-out1=bridge modem (main dsl line exclusive for hotel customers)
WAN2=second router with dhcp (second dsl line i am borrowing bandwidth daily 15:00-10:00 time)
i also have schedule to enable and disable WAN2 interface because this is the office internet i am borrowing bandwidth and i dont want to slow them down during working hours (morning).
is working as i want. when i disable wan2 (10:00 in the morning) customers are taking only from pppoe-out1 without any delay!
/ip firewall mangle
add chain=input in-interface=pppoe-out1 action=mark-connection new-connection-mark=WAN1_conn
add chain=input in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_conn
add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=to_WAN1
add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting dst-address=192.168.88.0/24 action=accept in-interface=bridge-local
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:4/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:4/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting connection-mark=WAN1_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN2
add dst-address=0.0.0.0/0 gateway=192.168.88.1 routing-mark=to_WAN1
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_WAN2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.88.1 distance=1
add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=2 check-gateway=ping
add chain=srcnat out-interface=WAN2 action=masquerade
Since you are using two Wan shouldn’t be like this?
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:2/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:2/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
I will try your script, the truth I need to add the same schedule to my WAN2 I need it to be available from 12:00 AM > 6:00 AM on daily basis..
Is your WAN2 interface assigned to any “master port” ? Or it’s set to “none” ?
Set to “none”
