add address=192.168.0.2 interface=pos_lan ##ether3
add address=192.168.1.2 interface=local_lan ##ether4
add address=xx.xx.xx.102/30 interface=WAN1##ether1
add address=xx.xx.xx.123/29 interface=WAN2##ether2
/ip firewall mangle
add chain=input in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_conn
add chain=input in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_conn
add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=to_WAN1
add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting dst-address=xx.xx.xx.102/30 action=accept in-interface=pos_lan
add chain=prerouting dst-address=xx.xx.xx.123/29 action=accept in-interface=local_lan
add chain=prerouting dst-address-type=!local in-interface=pos_lan per-connection-classifier=both-addresses:2/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=local_lan per-connection-classifier=both-addresses:2/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting connection-mark=WAN1_conn in-interface=pos_lan action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=local_lan action=mark-routing new-routing-mark=to_WAN2
add dst-address=0.0.0.0/0 gateway=xx.xx.xx.101 routing-mark=to_WAN1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=xx.xx.xx.121 routing-mark=to_WAN2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=xx.xx.xx.101 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=xx.xx.xx.121 distance=2 check-gateway=ping
add chain=srcnat out-interface=WAN1 action=masquerade
add chain=srcnat out-interface=WAN2 action=masquerade
can any one help me with this configuration. I want to implement it on my CCR series router.
