Have an RB3011 that currently has two WANs connected to it. ATT and Xfinity. Trying to do a very very basic setup using the RB3011 as a dual router, as I would do with my junipers, but seem to be having some issues.
My config is:
[admin@MikroTik] /ip route> /export compact hide-sensitive
# jun/12/2016 15:06:28 by RouterOS 6.35.2
# software id = NS6T-J47L
add name=bridge-phones
add name=bridge-users
set [ find default-name=ether2 ] name=att-lan
set [ find default-name=ether1 ] name=att-wan
set [ find default-name=ether3 ] master-port=att-lan
set [ find default-name=ether4 ] master-port=att-lan
set [ find default-name=ether7 ] name=xfinity-lan
set [ find default-name=ether6 ] name=xfinity-wan
/interface vlan
add interface=bridge-phones name=vlan-phones vlan-id=5
add interface=bridge-users name=vlan-users vlan-id=9
set [ find default-name=ether8 ] master-port=xfinity-lan
set [ find default-name=ether9 ] master-port=xfinity-lan
add name=pool-phones ranges=172.16.50.50-172.16.50.62
add name=pool-users ranges=10.0.19.2-10.0.19.62
add address-pool=pool-phones disabled=no interface=bridge-phones name=dhcp-phones
add address-pool=pool-users disabled=no interface=bridge-users name=dhcp-users
add bridge=bridge-users interface=ether5
add bridge=bridge-phones interface=ether10
add address=172.16.50.49/28 interface=bridge-phones network=172.16.50.48
add address=10.0.19.1/26 interface=bridge-users network=10.0.19.0
/ip dhcp-client
add add-default-route=no dhcp-options=hostname,clientid disabled=no interface=att-wan
add add-default-route=no dhcp-options=hostname,clientid disabled=no interface=xfinity-wan
add address=10.0.19.0/26 dns-server=208.67.220.220,208.67.222.222 gateway=10.0.19.1
add address=172.16.50.48/28 dns-server=208.67.220.220,208.67.222.222 domain=.com gateway=172.16.50.49
/ip firewall address-list
add address=172.16.50.48/28 list=list-xfinity
add address=10.0.19.0/26 list=list-att
/ip firewall mangle
add chain=prerouting dst-address=0.0.0.0/0 src-address-list=list-att
add chain=prerouting dst-address=0.0.0.0/0 src-address-list=list-xfinity
add action=mark-connection chain=prerouting in-interface=att-wan new-connection-mark=connection-att
add action=mark-connection chain=prerouting in-interface=xfinity-wan new-connection-mark=connection-xfinity
add action=mark-routing chain=prerouting connection-mark=connection-att new-routing-mark=route-att-wan src-address-list=list-att
add action=mark-routing chain=prerouting connection-mark=connection-xfinity new-routing-mark=route-xfinity-wan src-address-list=list-att
add action=mark-routing chain=output connection-mark=connection-att new-routing-mark=route-att-wan
add action=mark-routing chain=output connection-mark=connection-xfinity new-routing-mark=route-xfinity-wan
add action=masquerade chain=srcnat out-interface=xfinity-wan src-address-list=list-xfinity
add action=masquerade chain=srcnat out-interface=att-wan src-address-list=list-att
add check-gateway=ping distance=1 gateway=att-wan routing-mark=route-att-wan
add check-gateway=ping distance=1 gateway=xfinity-wan routing-mark=route-xfinity-wan
add check-gateway=ping distance=2 gateway=xfinity-wan
/system clock
set time-zone-name=America/Los_Angeles
/system routerboard settings
set protected-routerboot=disabled
Now, I can get the dhcp-client working, I can get the dhcp-servers working, even get the routes in ‘place’, but it doesn’t matter how I go about setting up the mangle and the routing distances, I cannot traverse the second path. It never seems to activate.
I have tried numerous permutations of the dhcp-client add-default-route, distance, and ip route add routing-mark, ip route gateway, etc.
Unfortunately, I seem to be stuck at this point, and nothing I have seen explains why (even with them both set to disabled on the dhcp-client and manually added via route add), I can never reach any source via the xfinity interface. I should be able to /ping interface=xfinity-wan address=8.8.8.8 and it would traverse that…
Anyone mind pointing me in the direction of what it is I am overlooking? Normally, on my Juniper, I would setup 2 separate routing instances, and then attach the vlans/interfaces to the routing instances on a per config basis (multiple vlans can exist within the routing instance, obviously), so it manages the default route, etc…
Thanks,
