jan/10/2018 21:58:18 by RouterOS 6.36.1
software id = 9U8J-EMVS
set [ find default-name=ether1 ] name=1-TTK
set [ find default-name=ether2 ] name=2-DOM-RU
set [ find default-name=ether3 ] name=3-LAN
set [ find default-name=ether4 ] name=4-DEV-LAN
/ip neighbor discovery
set "1-TTK" discover=no
/ip hotspot profile
add address=109.195.238.177/24 comment=defconf interface=2-DOM-RU network=
109.195.238.0
add address=178.76.252.194/29 interface=1-TTK network=178.76.252.192
add address=178.76.252.195/29 interface=1-TTK network=178.76.252.192
add address=178.76.252.196/29 interface=1-TTK network=178.76.252.192
add address=178.76.252.198/29 interface=1-TTK network=178.76.252.192
add address=178.76.252.197/29 interface=1-TTK network=178.76.252.192
add address=192.168.0.1/24 interface=3-LAN network=192.168.0.0
add address=192.168.2.1/24 interface=4-DEV-LAN network=192.168.2.0
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add action=accept chain=input comment="defconf: accept established,related"
add action=drop chain=input comment="defconf: drop all from WAN"
in-interface=1-TTK
in-interface=2-DOM-RU
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
add action=accept chain=forward comment="defconf: accept established,related"
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
connection-state=new disabled=yes in-interface=1-TTK
/ip firewall mangle
add action=accept chain=prerouting dst-address=178.76.252.192/29
in-interface=3-LAN
add action=accept chain=prerouting dst-address=109.195.238.0/24 in-interface=
3-LAN
add action=mark-connection chain=prerouting connection-mark=no-mark
in-interface=1-TTK new-connection-mark=1-TTK_conn passthrough=yes
in-interface=2-DOM-RU new-connection-mark=2-DOM-RU_conn passthrough=yes
dst-address-type=!local in-interface=3-LAN new-connection-mark=1-TTK_conn
passthrough=yes per-connection-classifier=both-addresses-and-ports:2/0
2-DOM-RU_conn passthrough=yes per-connection-classifier=
both-addresses-and-ports:2/1
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=
yes dst-address-type=!local in-interface=3-LAN new-connection-mark=
both-addresses-and-ports:3/2
add action=mark-routing chain=prerouting connection-mark=1-TTK_conn disabled=
yes in-interface=3-LAN new-routing-mark=to_1-TTK passthrough=yes
add action=mark-routing chain=prerouting connection-mark=2-DOM-RU_conn
disabled=yes in-interface=3-LAN new-routing-mark=to_2-DOM-RU passthrough=
yes
add action=mark-routing chain=output connection-mark=1-TTK_conn log-prefix=
TTK new-routing-mark=to_1-TTK passthrough=yes
add action=mark-routing chain=output connection-mark=2-DOM-RU_conn
log-prefix=DOMRU new-routing-mark=to_2-DOM-RU passthrough=yes
add action=netmap chain=dstnat comment=sip.generalcomp.ru dst-address=
178.76.252.198 dst-port=443 in-interface=1-TTK protocol=tcp to-addresses=
192.168.0.90 to-ports=443
178.76.252.198 dst-port=443 in-interface=1-TTK protocol=udp to-addresses=
add action=netmap chain=dstnat comment=conf.generalcomp.ru dst-address=
178.76.252.197 dst-port=443 in-interface=1-TTK protocol=tcp to-addresses=
192.168.0.91 to-ports=443
178.76.252.197 dst-port=443 in-interface=1-TTK protocol=udp to-addresses=
add action=netmap chain=dstnat comment=av.generalcomp.ru dst-address=
178.76.252.196 dst-port=443 in-interface=1-TTK protocol=tcp to-addresses=
192.168.0.92 to-ports=443
178.76.252.196 dst-port=443 in-interface=1-TTK protocol=udp to-addresses=
add action=netmap chain=dstnat comment=lync.generalcomp.ru dst-address=
178.76.252.195 dst-port=443 in-interface=1-TTK protocol=tcp to-addresses=
192.168.0.19 to-ports=4443
178.76.252.195 dst-port=443 in-interface=1-TTK protocol=udp to-addresses=
178.76.252.195 dst-port=80 in-interface=1-TTK protocol=tcp to-addresses=
192.168.0.19 to-ports=8080
178.76.252.195 dst-port=80 in-interface=1-TTK protocol=udp to-addresses=
add action=netmap chain=dstnat comment="EDGE SIP 5061" dst-address=
178.76.252.198 dst-port=5061 in-interface=1-TTK protocol=tcp
to-addresses=192.168.0.90 to-ports=5061
add action=netmap chain=dstnat comment="EDGE AV 50000-59999" dst-address=
178.76.252.196 dst-port=50000-59999 in-interface=1-TTK protocol=tcp
to-addresses=192.168.0.92 to-ports=50000-59999
178.76.252.196 dst-port=50000-59999 in-interface=1-TTK protocol=udp
add action=netmap chain=dstnat comment="EDGE STUN" dst-address=178.76.252.196
dst-port=3478 in-interface=1-TTK protocol=tcp to-addresses=192.168.0.92
to-ports=3478
add action=netmap chain=dstnat comment="RDP Belyaeva Alla" dst-address=
178.76.252.194 dst-port=40045 in-interface=1-TTK log=yes log-prefix=
"rdp test" protocol=tcp to-addresses=192.168.0.45 to-ports=3389
109.195.238.177 dst-port=40045 in-interface=2-DOM-RU protocol=tcp
add action=netmap chain=dstnat comment="RDP Alex Dol" dst-address=
178.76.252.194 dst-port=4078 in-interface=1-TTK protocol=tcp
to-addresses=192.168.0.78 to-ports=3389
add action=netmap chain=dstnat comment="RDP Aefrem" dst-address=
178.76.252.194 dst-port=40241 in-interface=1-TTK protocol=tcp
to-addresses=192.168.0.241 to-ports=3389
add action=netmap chain=dstnat comment="RDP Senchenko Marina" dst-address=
178.76.252.194 dst-port=4080 in-interface=1-TTK protocol=tcp
to-addresses=192.168.0.80 to-ports=3389
add action=netmap chain=dstnat comment="RDP Zachitaylov Sergei" dst-address=
178.76.252.194 dst-port=4064 in-interface=1-TTK protocol=tcp
to-addresses=192.168.0.64 to-ports=3389
add action=netmap chain=dstnat comment="RDP Chernykh Dmitriy" dst-address=
178.76.252.194 dst-port=40120 in-interface=1-TTK protocol=tcp
to-addresses=192.168.0.120 to-ports=3389
109.195.238.177 dst-port=40120 in-interface=2-DOM-RU protocol=tcp
add action=netmap chain=dstnat comment="RDP Sergei Pleshakov" dst-address=
178.76.252.194 dst-port=4063 in-interface=1-TTK protocol=tcp
to-addresses=192.168.0.63 to-ports=3389
add action=dst-nat chain=dstnat comment=
"NAT 1:1 192.168.0.19 na 178.76.252.195" dst-address=178.76.252.195
to-addresses=192.168.0.19
add action=src-nat chain=srcnat comment=
"NAT 1:1 192.168.0.19 na 178.76.252.195" src-address=192.168.0.19
to-addresses=178.76.252.195
"NAT 1:1 192.168.0.92 na 178.76.252.196" dst-address=178.76.252.196
"NAT 1:1 192.168.0.92 na 178.76.252.196" src-address=192.168.0.92
to-addresses=178.76.252.196
"NAT 1:1 192.168.0.91 na 178.76.252.197" dst-address=178.76.252.197
to-addresses=192.168.0.91
"NAT 1:1 192.168.0.92 na 178.76.252.196" src-address=192.168.0.91
to-addresses=178.76.252.197
"NAT 1:1 192.168.0.90 na 178.76.252.198" dst-address=178.76.252.198
"NAT 1:1 192.168.0.90 na 178.76.252.198" src-address=192.168.0.90
to-addresses=178.76.252.198
add action=masquerade chain=srcnat comment=MASQUERAD out-interface=1-TTK
add action=masquerade chain=srcnat out-interface=2-DOM-RU
add check-gateway=arp distance=1 gateway=178.76.252.193 routing-mark=to_1-TTK
add check-gateway=arp distance=1 gateway=109.195.238.254 routing-mark=
to_2-DOM-RU
add check-gateway=arp distance=2 gateway=109.195.238.254
add check-gateway=arp disabled=yes distance=1 gateway=178.76.252.193
178.76.252.193,109.195.238.254
/ip route rule
add src-address=178.76.252.192/29 table=to_1-TTK
add src-address=109.195.238.0/24 table=to_2-DOM-RU
add dst-address=192.168.0.0/24 table=main
add dst-address=192.168.2.0/24 table=main
add dst-address=0.0.0.0/0 table=main
add routing-mark=to_1-TTK table=to_1-TTK
add routing-mark=to_2-DOM-RU table=to_2-DOM-RU
/system clock
set time-zone-name=Europe/Moscow
/system routerboard settings
set memory-frequency=1200DDR protected-routerboot=disabled
So i have this config, loadbalancing seems working, but port-forward don't work. what am i doing wrong?
