Dual wan PCC routeros 7.20.2
This is my first post. After reading so much and make thousand trials with chatgpt, deepseek, grok and some others ai , not success at all. The only basic requierment I have is to balance both wans (ether7 is twice speed than ether8), failover and that server wireguard 192.168.0.200 has to go thru ether7 as peers resturns to that wan. Sorry for my english. This is my conf actual. Any aidea, help. Thanks in advance ! [admin@CASA-MikroTik] > /export
2025-10-29 17:56:01 by RouterOS 7.20.2
software id = 7YBB-5VKJ
model = RB5009UG+S+
serial number = Hxxxxxxxxxxx5X
add name=bridge-LAN protocol-mode=none
set [ find default-name=sfp-sfpplus1 ] disabled=yes
/interface eoip
add mac-address=xxxxxxxxxx name=eoip-garaje remote-address=192.168.10.250 tunnel-id=100
add name=pool-LAN ranges=192.168.0.100-192.168.0.200
add address-pool=pool-LAN interface=bridge-LAN name=dhcp-LAN
add bridge=bridge-LAN interface=ether1
add bridge=bridge-LAN interface=ether2
add bridge=bridge-LAN interface=ether3
add bridge=bridge-LAN interface=ether4
add bridge=bridge-LAN interface=ether5
add bridge=bridge-LAN interface=ether6
add bridge=bridge-LAN interface=*C
add bridge=bridge-LAN interface=eoip-garaje
add address=192.168.0.1/24 interface=bridge-LAN network=192.168.0.0
add address=192.168.10.2/24 comment="WAN Orange" interface=ether7 network=192.168.10.0
add address=192.168.20.2/24 comment="WAN O2" interface=ether8 network=192.168.20.0
add address=10.80.0.1/30 interface=eoip-garaje network=10.80.0.0
/ip dhcp-server lease
add address=192.168.0.106 client-id=1xxxxxxxxxxxxxe comment="aaaaaaaaaaaaaaaa" mac-address=xxxxxxxxxxxxxxxx server=dhcp-LAN
add address=192.168.0.101 comment="aaaaaaaaaaaaaa" mac-address=xxxxxxxxxxxxxxxxxxxx server=dhcp-LAN
add address=192.168.0.65 client-id=xxxxxxxxxxxxxxxxx mac-address=xxxxxxxxxxxxxxxxxx server=dhcp-LAN
add address=192.168.0.66 client-id=xxxxxxxxxxxxxxxxxx comment=aaaaaaaaaaaaaa mac-address=xxxxxxxxxxxxxxxxxx server=dhcp-LAN
add address=192.168.0.108 client-id=xxxxxxxxxxxxxxxxxxx comment="aaaaaaaaaaaaaa" mac-address=xxxxxxxxxxxxxxxxxxxxxxxx server=dhcp-LAN
add address=192.168.0.0/24 gateway=192.168.0.1
set allow-remote-requests=yes servers=192.168.0.1,8.8.8.8
add action=accept chain=forward dst-address=192.168.0.200 dst-port=51822 protocol=udp
add action=accept chain=forward dst-address=192.168.0.0/24 src-address=10.50.0.0/24
/ip firewall mangle
add action=mark-connection chain=prerouting new-connection-mark=orange_conn src-address=192.168.0.200
add action=masquerade chain=srcnat comment="NAT O2" out-interface=ether8
add action=masquerade chain=srcnat comment="NAT Orange" out-interface=ether7
add action=dst-nat chain=dstnat dst-port=51822 protocol=udp to-addresses=192.168.0.200
add action=masquerade chain=srcnat out-interface=ether7 src-address=192.168.0.200 to-addresses=192.168.10.1
add distance=1 dst-address=0.0.0.0/0 gateway=192.168.10.1 routing-table=main
add distance=2 dst-address=0.0.0.0/0 gateway=192.168.20.1 routing-table=main
add dst-address=192.168.10.0/24 gateway=10.80.0.2
add distance=1 dst-address=10.50.0.0/24 gateway=192.168.0.200
/system clock
set time-zone-name=Europe/Madrid
/system identity
set name=CASA-MikroTik
/system routerboard settings
set auto-upgrade=yes
There is tons of threads for PCC Load balancing here and on other places.
This is my current configration for PCC Dual WAN Dual Fallover, but with ether1 and ether2 as dual wan links. With some experience you can setup your too to your router.
Make note ! Current configuraiton will not merge both connection into one faster. I tryed configuration like that before, but issues some problems and revert to Fallover setup.
# 2025-10-29 18:36:00 by RouterOS 7.19.3
# software id = 0Q24-H92Q
# model = RB5009UPr+S+
# serial number =
add admin-mac=D4:01:C3:E5:2D:E1 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] poe-out=off
/interface pppoe-client
add disabled=no interface=ether1 name=pppoe-out1 use-peer-dns=yes user=\
    data
/interface wireguard
add comment=back-to-home-vpn listen-port=39825 mtu=1420 name=back-to-home-vpn
/disk
set usb1 media-interface=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/ip smb users
add name=admin
/disk settings
set auto-media-interface=bridge auto-smb-user=admin
/ip smb
set enabled=no
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add interface=ether2 list=WAN
    192.168.88.0
/ip cloud
set back-to-home-vpn=enabled ddns-enabled=yes ddns-update-interval=30m
/ip cloud back-to-home-user
add allow-lan=yes comment=RB5009UPr+S+ file-access=full file-access-path=\
    /usb1/disk name="dsdss" private-key=\
    "ggg" public-key=\
    "ggg"
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add add-default-route=no default-route-tables=main interface=ether2
add address=192.168.88.29 client-id=1:9c:14:63:7e:91:8b mac-address=\
    9C:14:63:7E:91:8B server=defconf
    192.168.88.1
set allow-remote-requests=yes servers=192.168.88.14
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add check-gateway=ping comment="Tran Kabel WAN" disabled=no distance=1 \
    dst-address=0.0.0.0/0 gateway=8.8.8.8 routing-table=main scope=30 \
    suppress-hw-offload=no target-scope=11
add check-gateway=ping comment="Tran Kabel WAN" disabled=no distance=2 \
    dst-address=0.0.0.0/0 gateway=8.8.4.4 routing-table=main scope=30 \
add comment="Tran Kabel WAN Recursive" disabled=no dst-address=8.8.8.8/32 \
    gateway=pppoe-out1 routing-table=main scope=11 suppress-hw-offload=no \
    target-scope=10
add comment="Tran Kabel WAN Recursive" disabled=no distance=1 dst-address=\
    8.8.4.4/32 gateway=pppoe-out1 routing-table=main scope=11 \
    suppress-hw-offload=no target-scope=10
add comment="Telekom WAN Backup" disabled=no distance=4 dst-address=0.0.0.0/0 \
    gateway=192.168.1.1 routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
/ip service
set ftp disabled=yes
set ssh disabled=yes
set telnet disabled=yes
set www disabled=yes
/ip traffic-flow
set active-flow-timeout=1m
/ip traffic-flow target
add dst-address=192.168.88.30 port=666 version=5
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
/system scheduler
add interval=30m name=traffic on-event=\
    "/import usb1/traffic-per-month/traffic.rsc" policy=read,write,sensitive \
    start-date=2025-05-13 start-time=16:55:00
/tool mac-server
/tool mac-server mac-winbox
How come I'm not surprised?
We can't be on the same topic; I'm allergic to Artificial Deficiency.
And I'm also allergic to routers without firewalls...
As an open relay you are a detriment to the entire network.
There is no configuration you can make, with any type of manufacturer,
that can combine the connection speeds using two lines from different operators [1],
(and even with the same one, unless specific agreements are made first)...
  1. except VPN with remote router in cloud â†Šī¸Ž
