Hi To all!
I’ve 2 WAN,
I would an help to set ip from 192.168.2.2 to 192.168.2.99 going on WAN1(modem Gw:192.168.0.1)
ip from 192.168.2.100 to 192.168.2.200 going on WAN2(antenna GW:192.168.1.1)
Then, an client(192.168.2.8 ) in outgoing/incoming traffic on WAN1(modem), and reached by internet (port forward: 11002) by WAN2(antenna)
and ip that is not in the range (router itself 192.168.2.1 and range 192.168.2.251 to 254) select manual what WAN must be used..
thanks a lot
This is my only parameter
/ip address print
# ADDRESS NETWORK INTERFACE
0 192.168.0.4/24 192.168.0.0 ether6_antenna
1 192.168.1.2/24 192.168.1.0 ether2_modem
2 192.168.2.1/24 192.168.2.0 ether5
