Dual WAN setup, _without_ load balancing and failover
Hi
I have a thread going: http://forum.mikrotik.com/t/cannot-nat-incoming-ports-kindof-dual-wan-setup/35684/15
However, i am not able to port forward from internet and to a internal SSH server. Since my setup could be wrong somewhere, and causing this to not work, i will try to ask for a setup wich will work as excepted, and allow port forwarding to internal machines.
Earlier i solved my needs by having two Wireless Dlink’s, each connected to their respective WAN’s. I switched between them when i needed to reach my internal work network.
Right now i have, trough one MT router access to both networks, just as i want it, but no port forward what so ever.
What i have:
Alix board, 3 eth, 1 wlan - 1 external ISP (DHCP) via Cable (Wan1) , one static ip (Wan2), connected to my work network via a MT CPE.
What i want:
Internal network: 10.0.0.0/24
I need all traffic to go via external ISP (Wan1), except two networks, wich i need to reach via Wan2.
Nat from Wan1 port 22 , to 10.0.0.53 - port 22
Any help is much appreciated.
M-sport
I solved the issue in the other post.
M-sport
