Hi Everyone,
I’m kind of new to MikoTik and I wanted to setup a dual wan configuration with port forwards. WAN1 should be used as default connection, WAN2 as failover and for some incoming connections.
My configuration seems to work, but port forwarding on WAN2 is terribly slow. I think I’m missing something essential, but I wasn’t able to figure out what. If I disable WAN1, the forwarded SSH works as it should, but if WAN1 is enabled it takes seconds to have response from the server inside LAN.
I checked the forum but I wasn’t able to find the solution what works in my case. Can you help me please?
Here is my config:
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] name=WAN2
set [ find default-name=ether4 ] master-port=ether3
set [ find default-name=ether5 ] master-port=ether3
/ip neighbor discovery
set WAN1 discover=no
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.0.2-192.168.0.99
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge interface=ether3
add comment=defconf interface=WAN1 list=WAN
add address=192.168.0.1/24 comment=defconf interface=bridge network=\
192.168.0.0
add address=192.168.1.2/24 interface=WAN1 network=192.168.1.0
add address=192.168.2.2/24 interface=WAN2 network=192.168.2.0
add address=192.168.0.0/24 comment=defconf gateway=192.168.0.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.0.1 name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall mangle
add action=mark-connection chain=prerouting connection-mark=no-mark \
in-interface=WAN1 new-connection-mark=WAN1_conn passthrough=no
in-interface=WAN2 new-connection-mark=WAN2_conn passthrough=no
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
in-interface=bridge new-routing-mark=to_WAN1 passthrough=no
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
in-interface=bridge new-routing-mark=to_WAN2 passthrough=no
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add action=dst-nat chain=dstnat dst-address=192.168.2.2 dst-port=29022 \
protocol=tcp to-addresses=192.168.0.101 to-ports=22
add distance=1 gateway=192.168.1.1 routing-mark=to_WAN1
add distance=1 gateway=192.168.2.1 routing-mark=to_WAN2
add distance=2 gateway=192.168.2.1
