Hi all
So I recently activated the VPN remote login to Winbox (Via Quickset).
It worked, however, shortly after this it occurred that when I have both my WAN interfaces active (load balanced) named ISP1 and ISP2 the internet throughput is very slow/non-existent/TeamViewer connection is lost.
When ISP2 only is active, throughput is okay. The moment ISP1 is enabled, internet is lost.
This could either be a coincidental occurrence with an issue with my ISP that started at exactly the same time, or I broke something by trying to get the VPN going.
I’m currently out of the country where my MT is.
Your ideas/input would be appreciated.
Thanks!
