Dual WAN + Wireguard tunnel ?
Long time Mikrotik user but not at all experienced in more complex networking.
I have recently got connected with Starlink internet as my existing connection was very high latency at times and low bandwidth. However Starlink suffers from a lot of 20-60 second drop outs.
My question is. Can I set up a Multi-Wan failover situation that uses a wireguard tunnel to a VPS on both interfaces, in the event WAN1 ( Starlink ) drops I can seamlessly failover to WAN2. I have a failover set up currently but when the IP address changes games like WoW drop the connection as the ip address has changed(assumed). Starlink is great when it works but I have some frustrated family members who are not happy with getting kicked out of game at inopportune moments of there gaming.
If this is not viable can anyone suggest me a solution to look into?
Cheers,
Pat.
If you want WG to VPS as “third WAN” and use it to access internet (or just games, if you could identify only their traffic, which may not be easy), it should work. Either with two tunnels (one for each WAN) or only one (WG is very good with roaming). But whether it will switch fast enough for games, that’s a question.
