I'm trying to configure my MikroTik hEX (RouterOS v7.19.3 - E50UG) with the following network segmentation:
Main LAN (192.168.10.0/24) → Uses UVT connection (pppoe-out1)
Guest network (192.168.50.0/24) → Uses CZNET connection (ether1)
IoT network (192.168.66.0/24) → No direct internet access
Configuration already done
Connection Marking
Main LAN traffic marked as
uvt_conn -
Guest traffic marked as
cznet_conn
Policy Routing
Two separate routing tables:
to-wan-cznetandto-wan-uvt -
Marked connections routed through appropriate WAN
Network Address Translation (NAT)
Main LAN traffic masqueraded through UVT
Guest traffic masqueraded through CZNET
VLAN Setup
VLAN 50 for guest network
VLAN 66 for IoT devices
VLAN 848 for UVT PPPoE connection
DHCP Services
- Separate DHCP pools for each network segment
Problem Description
Connections from LANs are not working. I can ping the router itself, but traffic is not being sent to the correct WAN interface.
Question
I have no idea what I'm missing. Any suggestions on what could be wrong with my configuration? You can see details in config below
Thanks!
/ip address print
Flags: D - DYNAMIC
Columns: ADDRESS, NETWORK, INTERFACE
# ADDRESS NETWORK INTERFACE
;;; defconf
0 192.168.10.1/24 192.168.10.0 bridge
1 10.200.126.135/26 10.200.126.128 ether1
;;; iot
2 192.168.66.1/24 192.168.66.0 vlan66
3 D 178.15.15.15/32 10.11.5.146 pppoe-out1
;;; guest
4 192.168.50.1/24 192.168.50.0 vlan50
/interface print
Flags: R - RUNNING; S - SLAVE
Columns: NAME, TYPE, ACTUAL-MTU, L2MTU, MAX-L2MTU, MAC-ADDRESS
# NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU MAC-ADDRESS
;;; CZNET
0 R ether1 ether 1500 1600 2048 F4:1E:57:AD:B7:F6
;;; UVTNET
1 R ether2 ether 1500 1596 2026 F4:1E:57:AD:B7:F7
2 RS ether3 ether 1500 1596 2026 F4:1E:57:AD:B7:F8
3 RS ether4 ether 1500 1596 2026 F4:1E:57:AD:B7:F9
4 S ether5 ether 1500 1596 2026 F4:1E:57:AD:B7:FA
;;; defconf
5 R bridge bridge 1500 1596 F4:1E:57:AD:B7:F7
6 R lo loopback 65536 00:00:00:00:00:00
;;; uvt
7 R pppoe-out1 pppoe-out 1492
;;; guest
8 R vlan50 vlan 1500 1592 F4:1E:57:AD:B7:F7
;;; iot
9 R vlan66 vlan 1500 1592 F4:1E:57:AD:B7:F7
;;; UVT
10 R vlan848 vlan 1500 1592 F4:1E:57:AD:B7:F7
/interface vlan print
Flags: R - RUNNING
Columns: NAME, MTU, ARP, VLAN-ID, INTERFACE
# NAME MTU ARP VLAN-ID INTERFACE
;;; guest
0 R vlan50 1500 enabled 50 bridge
;;; iot
1 R vlan66 1500 enabled 66 bridge
;;; UVT
2 R vlan848 1500 enabled 848 ether2
/interface bridge print
Flags: D - dynamic; X - disabled, R - running
0 R ;;; defconf
name="bridge" mtu=auto actual-mtu=1500 l2mtu=1596 arp=enabled arp-timeout=auto mac-address=F4:1E:57:AD:B7:F7 protocol-mode=rstp fast-forward=yes igmp-snooping=no auto-mac=no admin-mac=F4:1E:57:AD:B7:F7
ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=no dhcp-snooping=no port-cost-mode=long mvrp=no max-learned-entries=auto
/interface bridge port print
Flags: I - INACTIVE; H - HW-OFFLOAD
Columns: INTERFACE, BRIDGE, HW, HORIZON, TRUSTED, FAST-LEAVE, BPDU-GUARD, EDGE, POINT-TO-POINT, PVID, FRAME-TYPES
# INTERFACE BRIDGE HW HORIZON TRUSTED FAST-LEAVE BPDU-GUARD EDGE POINT-TO-POINT PVID FRAME-TYPES
;;; defconf
0 H ether3 bridge yes none no no no auto auto 1 admit-all
;;; defconf
1 H ether4 bridge yes none no no no auto auto 1 admit-all
;;; defconf
2 IH ether5 bridge yes none no no no auto auto 1 admit-all
/ip route print detail
Flags: D - dynamic; X - disabled, I - inactive, A - active; c - connect, s - static, r - rip, b - bgp, o - ospf, i - is-is, d - dhcp, v - vpn, m - modem, y - bgp-mpls-vpn; H - hw-offloaded; + - ecmp
0 Xs dst-address=0.0.0.0/0 routing-table=main gateway=10.200.126.129 distance=2 scope=30 target-scope=10 suppress-hw-offload=no
1 As dst-address=0.0.0.0/0 routing-table=main gateway=pppoe-out1 immediate-gw=pppoe-out1 distance=1 scope=30 target-scope=10 suppress-hw-offload=no
DAc dst-address=10.11.5.146/32 routing-table=main gateway=pppoe-out1 immediate-gw=pppoe-out1 distance=0 scope=10 target-scope=5 local-address=178.17.14.240%pppoe-out1
DAc dst-address=10.200.126.128/26 routing-table=main gateway=ether1 immediate-gw=ether1 distance=0 scope=10 target-scope=5 local-address=10.200.126.135%ether1
DAc dst-address=192.168.10.0/24 routing-table=main gateway=bridge immediate-gw=bridge distance=0 scope=10 target-scope=5 local-address=192.168.10.1%bridge
DAc dst-address=192.168.50.0/24 routing-table=main gateway=vlan50 immediate-gw=vlan50 distance=0 scope=10 target-scope=5 local-address=192.168.50.1%vlan50
DAc dst-address=192.168.66.0/24 routing-table=main gateway=vlan66 immediate-gw=vlan66 distance=0 scope=10 target-scope=5 local-address=192.168.66.1%vlan66
2 As dst-address=0.0.0.0/0 routing-table=to-wan-cznet gateway=10.200.126.129 immediate-gw=10.200.126.129%ether1 distance=1 scope=30 target-scope=10 suppress-hw-offload=no
3 As dst-address=0.0.0.0/0 routing-table=to-wan-uvt gateway=pppoe-out1 immediate-gw=pppoe-out1 distance=1 scope=30 target-scope=10 suppress-hw-offload=no
4 As dst-address=209.38.255.33/32 routing-table=to-wan-uvt gateway=pppoe-out1 immediate-gw=pppoe-out1 distance=1 scope=30 target-scope=10 suppress-hw-offload=no
/ip firewall mangle print
Flags: X - disabled, I - invalid; D - dynamic
0 D ;;; special dummy rule to show fasttrack counters
chain=prerouting action=passthrough
1 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
2 D ;;; special dummy rule to show fasttrack counters
chain=postrouting action=passthrough
3 ;;; LAN traffic
chain=prerouting action=mark-connection new-connection-mark=uvt_conn passthrough=yes dst-address-type=!local in-interface=bridge log=no log-prefix="z lan"
4 ;;; LAN traffic z vlan50
chain=prerouting action=mark-connection new-connection-mark=cznet_conn passthrough=yes src-address=192.168.50.0/24 dst-address-type=!local connection-mark=no-mark log=no log-prefix=""
5 ;;; uvt incoming
chain=prerouting action=mark-connection new-connection-mark=uvt_conn passthrough=yes connection-mark=no-mark in-interface=pppoe-out1 log=yes log-prefix="z uvt"
6 ;;; cznet incoming
chain=prerouting action=mark-connection new-connection-mark=cznet_conn passthrough=yes in-interface=ether1 log=yes log-prefix="z cznet"
7 ;;; cznet
chain=output action=mark-routing new-routing-mark=to-wan-cznet passthrough=no connection-mark=cznet_conn log=no log-prefix="output cznet"
8 ;;; uvt
chain=output action=mark-routing new-routing-mark=to-wan-uvt passthrough=no connection-mark=uvt_conn log=no log-prefix="output uvt"
9 ;;; cznet
chain=prerouting action=mark-routing new-routing-mark=to-wan-cznet passthrough=no connection-mark=cznet_conn log=no log-prefix="to-wan- cznet"
10 ;;; uvt
chain=prerouting action=mark-routing new-routing-mark=to-wan-uvt passthrough=no connection-mark=uvt_conn log=no log-prefix="to-wan uvt"
/ip firewall nat print
0 ;;; defconf: masquerade
chain=srcnat action=masquerade src-address=192.168.10.0/24 routing-mark=to-wan-uvt log=no log-prefix="" ipsec-policy=out,none
1 ;;; defconf: masquerade
chain=srcnat action=masquerade src-address=192.168.50.0/24 routing-mark=to-wan-cznet log=no log-prefix="" ipsec-policy=out,none
/ip firewall filter print
1 ;;; defconf: accept established,related,untracked
chain=input action=accept connection-state=established,related,untracked
2 chain=input action=accept protocol=gre log=no log-prefix=""
3 ;;; defconf: drop invalid
chain=input action=drop connection-state=invalid
4 ;;; defconf: accept ICMP
chain=input action=accept protocol=icmp
5 ;;; defconf: accept to local loopback (for CAPsMAN)
chain=input action=accept dst-address=127.0.0.1
6 ;;; defconf: drop all not coming from LAN
chain=input action=drop in-interface-list=!LAN log=no log-prefix=""
7 ;;; defconf: accept in ipsec policy
chain=forward action=accept ipsec-policy=in,ipsec
8 ;;; defconf: accept out ipsec policy
chain=forward action=accept ipsec-policy=out,ipsec
9 ;;; defconf: fasttrack
chain=forward action=fasttrack-connection hw-offload=yes connection-state=established,related log=no log-prefix=""
10 ;;; defconf: accept established,related, untracked
chain=forward action=accept connection-state=established,related,untracked
11 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid
12 ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN
13 ;;; allow to vlan66 from vlan1
chain=forward action=accept src-address=192.168.10.0/24 dst-address=192.168.66.0/24 log=no log-prefix=""
14 chain=forward action=drop src-address=192.168.66.0/24 out-interface-list=WAN log=no log-prefix=""
15 ;;; Block guest to LAN1
chain=forward action=drop src-address=192.168.50.0/24 dst-address=192.168.10.0/24 log=no log-prefix=""
16 ;;; Block guest to LAN2
chain=forward action=drop src-address=192.168.50.0/24 dst-address=192.168.66.0/24 log=no log-prefix=""
17 ;;; Block management from guest
chain=input action=drop protocol=tcp in-interface=vlan50 dst-port=8291,22,23,80,443,8728,8729
18 ;;; Allow guest to internet
chain=forward action=accept in-interface=vlan50 out-interface-list=WAN
/interface pppoe-client print
Flags: X - disabled, I - invalid; R - running
0 R ;;; uvt
name="pppoe-out1" max-mtu=1492 max-mru=1492 mrru=disabled interface=vlan848 user="xxx" password="xxx" profile=default keepalive-timeout=10 service-name="" ac-name="" add-default-route=no dial-on-demand=no
use-peer-dns=no allow=pap,chap,mschap1,mschap2
/interface list print
Flags: * - BUILTIN
Columns: NAME
# NAME
;;; contains all interfaces
0 * all
;;; contains no interfaces
1 * none
;;; contains dynamic interfaces
2 * dynamic
;;; contains static interfaces
3 * static
;;; defconf
4 WAN
;;; defconf
5 LAN
/interface list member print
Columns: LIST, INTERFACE
# LIST INTERFACE
;;; defconf
0 LAN bridge
;;; defconf
1 WAN ether1
2 WAN pppoe-out1
/ip dhcp-server print
Columns: NAME, INTERFACE, ADDRESS-POOL, LEASE-TIME
# NAME INTERFACE ADDRESS-POOL LEASE-TIME
0 defconf bridge dhcp 30m
1 dhcp66 vlan66 dhcp66 30m
2 dhcp50 vlan50 dhcp50 30m
/ip pool print
Columns: NAME, RANGES, TOTAL, USED, AVAILABLE
# NAME RANGES TOTAL USED AVAILABLE
0 dhcp 192.168.10.38-192.168.10.243 206 9 197
;;; v66
1 dhcp66 192.168.66.10-192.168.66.240 231 10 221
;;; v50
2 dhcp50 192.168.50.10-192.168.50.240 231 2 229e
