Have a working Dual WAN. Odd issue is I have a (2) Ping prompt’s running; one to google.com and the other to 8.8.8.8
when I disconnect either of the WAN’s one of the Ping’s stops and the other continues fine. The Ping’s switch back and forth and the symptom remains constant depending on which WAN I disconnect.
I suspect that it is a DNS setting. WAN1 is DHCP from Mikrotik router and WAN2 is Static from Mikrotik router. All works but I know if I am loosing the name or ip resolution that it will effect something sooner or later?
Question I have is; if WAN1 pulls a static IP address it creates a dynamic DNS gateway route. I did enter in my own static for both WAN’s with no change. How do I get the resolution to remain constant on both IP and name?
