I am failing to get working router with two LANs connected at the same time. Since one connection bandwidth is much higher than the other, the target is to have failover switching. But I wanted to have both connections available to at the same time - ie. available services either from public1.domain.net and public2.domain.net. I will have several services ports forwarded from router (ftp, ssh, rdp) to LAN machines.
/ip route rule print
0 routing-mark=wan1 action=lookup table=wan1
1 dst-address=192.168.10.0/24 action=lookup table=main
2 routing-mark=wan2 action=lookup table=wan2
/ip route print detail
0 A S dst-address=0.0.0.0/0 gateway=10.10.30.1
gateway-status=10.10.30.1 reachable via ether1 distance=1 scope=30
target-scope=10 routing-mark=wan1
1 A S dst-address=10.10.30.0/24 pref-src=10.10.30.251 gateway=ether1
gateway-status=ether1 reachable distance=1 scope=10 target-scope=10
routing-mark=wan1
2 S dst-address=0.0.0.0/0 gateway=10.10.20.1
gateway-status=10.10.20.1 unreachable distance=1 scope=30
target-scope=10 routing-mark=wan2
3 S dst-address=10.10.20.0/24 pref-src=10.10.20.254 gateway=ether3
gateway-status=ether3 unreachable distance=1 scope=10 target-scope=10
routing-mark=wan2
4 A S dst-address=0.0.0.0/0 gateway=10.10.30.1
target-scope=10
5 DC dst-address=10.10.20.0/24 pref-src=10.10.20.254 gateway=ether3
gateway-status=ether3 unreachable distance=255 scope=10
6 ADC dst-address=10.10.30.0/24 pref-src=10.10.30.251 gateway=ether1
gateway-status=ether1 reachable distance=0 scope=10
7 ADC dst-address=192.168.10.0/24 pref-src=192.168.10.130 gateway=ether2
gateway-status=ether2 reachable distance=0 scope=10
/ip firewall nat print
1 chain=srcnat action=masquerade to-addresses=10.10.30.251
src-address=192.168.0.0/16 routing-mark=wan1 out-interface=ether1 log=no
log-prefix=""
2 chain=srcnat action=src-nat to-addresses=10.10.20.254
src-address=192.168.0.0/16 routing-mark=wan2 out-interface=ether3 log=no
log-prefix=""
3 chain=dstnat action=dst-nat to-addresses=192.168.10.253 to-ports=22
protocol=tcp in-interface=!ether2 dst-port=22 log=no log-prefix=""
/ip firewall mangle print
0 D ;;; special dummy rule to show fasttrack counters chain=prerouting
1 D ;;; special dummy rule to show fasttrack counters chain=forward
2 D ;;; special dummy rule to show fasttrack counters chain=postrouting
3 chain=input action=mark-connection new-connection-mark=wan2 passthrough=yes connection-state=new
in-interface=ether3 connection-mark=no-mark log=no log-prefix="new wan2"
4 chain=input action=mark-connection new-connection-mark=wan1 passthrough=yes connection-state=new
in-interface=ether1 connection-mark=no-mark log=no log-prefix="wan1"
5 ;;; determining default connectivity...
chain=prerouting action=mark-connection new-connection-mark=wan1 passthrough=yes connection-state=new
dst-address=!192.168.0.0/16 in-interface=ether2 connection-mark=no-mark log=no log-prefix=""
6 chain=output action=mark-connection new-connection-mark=wan1 passthrough=yes connection-state=new
out-interface=ether1 connection-mark=no-mark log=yes log-prefix="wan1"
7 chain=postrouting action=mark-connection new-connection-mark=wan2 passthrough=yes
connection-state=related,new out-interface=ether3 connection-mark=no-mark log=yes log-prefix="post! "
8 ;;; wan1
chain=prerouting action=mark-routing new-routing-mark=wan1 passthrough=no connection-mark=wan1 log=no
log-prefix=""
9 ;;; wan2
chain=prerouting action=mark-routing new-routing-mark=wan2 passthrough=no connection-mark=wan2 log=no
log-prefix=""
10 XI chain=forward action=accept connection-state=related,new connection-mark=no-mark log=no log-prefix=""
11 chain=forward action=log connection-state=new connection-mark=no-mark log=no log-prefix="new no"
12 chain=forward action=log connection-state=new connection-mark=wan1 log=no log-prefix="new w1"
Unfortunately it doesn’t work, but I can’t find out why! I can see returning packets from upstream router during my testing not being considered being part of the same connection. Why?? Snippet from my log illustrating the case:
14:03:12 firewall,info new w1 forward: in:ether2 out:ether1, src-mac 00:1d:60:55:58:83, proto UDP, 192.168.10.253:60135->10.10.10.4:53, len 65
14:03:12 firewall,info new no forward: in:ether1 out:ether2, src-mac 4c:5e:0c:1f:45:3d, proto UDP, 10.10.10.4:53->192.168.10.253:60135, len 117
14:03:17 firewall,info new w1 forward: in:ether2 out:ether1, src-mac 00:1d:60:55:58:83, proto UDP, 192.168.10.253:35805->10.10.10.3:53, len 65
14:03:17 firewall,info new no forward: in:ether1 out:ether2, src-mac 4c:5e:0c:1f:45:3d, proto UDP, 10.10.10.3:53->192.168.10.253:35805, len 117
14:03:22 firewall,info new w1 forward: in:ether2 out:ether1, src-mac 00:1d:60:55:58:83, proto UDP, 192.168.10.253:60135->10.10.10.4:53, len 65
I would appreciate someone checking it, because I have been labouring with this supposedly simple matter about three days without advancing any further… :-/
