Dual Wan
Hello Everyone !
Want to ask a question
Which router can manage this below route table ?
if router have 4 port Lan/wan
port 1 & 2 use as wan ( dual wan )
port 3 & 4 use as lan ( different two router/ap )
port 1 wan use only for lan 3
port 2 wan use only for lan 4
if wan 1 fail use failover on lan 4
if wan 2 fail use failover on lan 3
that can be possible ?
thanks
sky is the limit with mikrotik
Yes very easy to do!
Hint, nothing is easy, but with the help of people here you will be singing and dancing and not forever configuring your router..
Multi-WAN scenarios are very common.
