dualwan problem
hi, I’ve just got a ccr1016 and have 2 wan (static ip, different ISP) connected.
by now, wan 1 is ok (default route, have some dst-nat/src-nat with it).
but wan 2 is not usable, think I maby miss some routing settings?
(both wan 1 & 2 are not for internet surfing purpose, just for specific servers in Lan, mostly port mapping)
  1. Line 2 was tested with computers, it’s ok. (can access internet)
  2. wan 2 can ping its gateway (isp side), but ping internet ip failed.
  3. have tried disable all filter policy, no work.
  4. if i disable wan 1, wan 2 is usable.
  5. tried add lower priority default for wan 2, no work.
  6. ping or telnet wan 2 from internet failed, got 1 msg everytime :
15:04:17 firewall,info dstnat: in:ether2 out:(none), src-mac b4:a4:e3:95:d4:2c, proto TCP (SYN), 23.110.80.42:12200->1.2.3.4:80, len 40
so what should I do to make wan 2 usable? any advice is appreciated. :smiley:
I’ve add below config, but still no work.
 /ip firewall mangle
 0    chain=prerouting action=mark-connection new-connection-mark=cu_conn_1 passthrough=yes src-address=172.16.16.158 log=no log-prefix=""
 1    chain=input action=mark-connection new-connection-mark=cu_conn_1 passthrough=yes in-interface=ether2 log=no log-prefix=""
 2    chain=prerouting action=mark-routing new-routing-mark=cu_route_1 passthrough=yes connection-mark=cu_conn_1 log=no log-prefix=""
 3    chain=output action=mark-routing new-routing-mark=cu_route_1 passthrough=yes connection-mark=cu_conn_1 log=no log-prefix=""
 0 A S  dst-address=0.0.0.0/0 gateway=1.85.12.105 gateway-status=1.85.12.105 reachable via  ether2 distance=2 scope=30 target-scope=10
 1 A S  dst-address=0.0.0.0/0 gateway=11.8.22.241 gateway-status=11.8.22.241 reachable via  ether1 distance=1 scope=30 target-scope=10
 chain=srcnat action=src-nat to-addresses=1.85.12.110 src-address=172.16.16.158 log=yes log-prefix=""
 chain=dstnat action=dst-nat to-addresses=172.16.16.158 to-ports=80 protocol=tcp dst-address=1.85.12.110 dst-port=80 log=yes log-prefix=""
LAN IP = 172.16.16.158 (intend public IP = 1.85.12.110)
WAN 1 = 11.8.22.240/29 (eth1)
WAN 2 = 1.85.12.104/29 (eth2)
solved. just 1 mangle rule(source ip) & routing mark is enough.
