Dude 1.x to 2.x
I noticed that importing map on dude 2.x that has ben previously exported from dude 1.x doestn work as it should!
What I want to know is, will it be fixed? because now Im using dude 1.2 and if its imposible to use my dude 1.x maps on the dude 2.x then it would be stoopid to continue drawing my network in old 1.x version.
you should send us your export file that does not work, to help us fix the
problem (we cannot reproduce it)
send it to support@mikrotik.com
