dude 2.01 beta
-web server is not working…I cannot log in?
-local map export (new feature) - where does it save exported file?
-how to setup speed of refreshing speed of links?
thx…
great product :slight_smile:
hm…memory leak?
on my server dude is currently using 740 mb of memory?
after running for 10 minutes…
web server: ok we see what you mean
map export: currently maps are saved in directory where dude is installed
link refresh speed: currently no way to change (10 seconds)
memory leak: send us your export file to support@mikrotik.com to help us
resolve this issue
actually, we have resolved memory leak problem, it was png network map export, you can disable it until next release of beta dude.
I could not found that file…? maybe it was bug that it was not saved to disk, but to memory…
